October 12, 20178 yr Either a tool or gauge? Given to me by a non-black smithing friend who found it at a fleamarket. The name looks like Penberthy. Opposite side or marked 1, 3/4, 1/2. It is 2" long and actual measurements of the sizes are 11/16", 1/2", 3/8". "Looks" like it is cast iron.
October 12, 20178 yr Inside/outside sliding caliper. You will note that their is a place to read the inside and outside (marked "out") of objects.
October 13, 20178 yr Author 5 minutes ago, Charles R. Stevens said: Inside/outside sliding caliper. You will note that their is a place to read the inside and outside (marked "out") of objects. caliper was set there for size reference. Not part of the "thingy". Shoulda mentioned that. Sorry. Ill try there Farmall. I had no luck with Penberthy gauge or similar searches.
October 13, 20178 yr I just ran across this info. This is the tool to install the "tail pipe" (so called) of a Penberthy Injector. Actually there are three tail pipes used on the injector: one for the steam, one for the water, and one for the combined boiler feed. Injectors come in graduated sizes hence the graduated squares. http://www.practicalmachinist.com/vb/antique-machinery-and-history/help-identify-device-marked-penberthy-172972/
October 13, 20178 yr Author Button, sounds and looks like a dead ringer. Thanks for solving the mystery!
