the iron dwarf Posted August 18, 2017 Share Posted August 18, 2017 got a bit of 4140 recently and have started work on it its about a 6" cube ( 150mm cube ) first tried it out and it works ok next will clean it up a bit and add a different rad to each edge on one face, the opposite face is left with sharp edges. on one side a couple of holes will be drilled for punching etc and some small divots made for riveting Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 18, 2017 Share Posted August 18, 2017 On the holes, will you be drilling straight down then a second hole angled up from the side to meet it or drilling straight through? Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 18, 2017 Share Posted August 18, 2017 Might consider 2 radie a side. That's 3" as to your prichel holes, one can undercut it as well as cross drill. With 6 working faces you can have a bomb multi tool. Quote Link to comment Share on other sites More sharing options...
Lou L Posted August 18, 2017 Share Posted August 18, 2017 Glen from GStongs uses something similar but he machines them quite ingeniously to make excellent anvils. If you have access to a mill you may want to look at this video for ideas. Quote Link to comment Share on other sites More sharing options...
Donnie Posted August 18, 2017 Share Posted August 18, 2017 I use a block anvil. I've had several London patterned anvils. Never really used the horn. Turned hooks and scrolls off the edge. Always punched holes on the face. To each their own. A block anvil works for me. Quote Link to comment Share on other sites More sharing options...
Jackdawg Posted August 19, 2017 Share Posted August 19, 2017 I have to admit my lump of steel like this (200 high, otherwise the same) gets more use than my anvil. I am currently on the look out for an even bigger one. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted August 19, 2017 Author Share Posted August 19, 2017 4 edges with different radii plus the big one on another 4 and 4 sharp edges, some useful holes and divots for riveting and punching, 2 flat faces Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted August 19, 2017 Author Share Posted August 19, 2017 the holes only go about 2" deep but I consider them useful Quote Link to comment Share on other sites More sharing options...
