3"x3" steel plates
I recently found a whole 5 gallon bucket worth of 3x3 steel plates. Some look to be 1/2 inch and some look to be 3/8 inch. Was wondering if there's any hot uses for these because if so, I may have hit a small payload because they are free! Any input is much appreciated!
im sure there are about a billion different things that can be made, just wonder if 3x3 is too small to bother with
Weld a piece of flat bar, on end and diagonally across the bottom of the metal. Weld whatever you want to the top and call it a hardie plate.
You can dish or sink them for bowls, candle holders, sculptural elements. Lots of guys make some cool things with squares about that size. The 1/2" I'd be thinking of using them structurally. I'd sure bring the bucket home with me.
I loaded them up, every last one of them and carried them a mile and a half to my truck. The ones I thought were 1/2 were actually 3/4, and the ones I thought 3/8 were actually 1/2 so it turned out good. 20 of each size
Weld them up into a 24" square checkerboard (high-and-low instead of black-and-white) and then forge a set of chess pieces.
No, wait -- you only have 20 of each, and you'd need 32 (64 total). Are you sure they don't have more?
I think I'm going to have to find me a few pieces myself now. I've been thinking about forging a chess set for a while just haven't made the time.
6 hours ago, Anthony Mans said:
That would be neat though but I emptied the bucket Haha
It just occurs to me that you could take one of squares and divide it into four 1½" x 1½" squares. Leave one diagonal pair alone, and texture the other pair in some way (chisel, etch, subtle ball peening, etc). Repeat fifteen times, assemble into a full  8 x 8 chessboard.
This way, you get the same effect, but you only use a quarter of the your 3x3s, and you don't have to make the chess pieces quite as big..
Polish them, charter a bush plane and sprinkle Redwood size glitter? Hmmmm, Chess set's probably a better idea.
