May 22, 20179 yr Hello everyone any thoughts on the majestic forge. I am looking at the three burner knife maker
May 22, 20179 yr Do you have any questions that the 87 hits you get when you search all content majestic don't answer?
May 23, 20179 yr Here is a different question, and possible answers: Why in the world would a knife maker's forge need three burners? Possible answers: It's really for use on swords by the worlds fastest blacksmith; wow, they must really be weak burners; like oversize cars, their only purpose is to allow the manufacturer to charge more money for a poor product
May 24, 20179 yr 3 burners are what the market expects for a blade forge. A smart manufacturer provides what the market wants. . . . Hmmmm? Frosty The Lucky.
May 24, 20179 yr Hey, but they sell. With a tag line like "as seen on forged in fire" it dignifies them. I'm sure the manufacturer is enjoying all the attention.
May 24, 20179 yr Hey Frosty , How many of your 3/4" T burners can you put on One Propane regulator, a regulator with 1/4" ports like this one.
May 24, 20179 yr I don't know I've never used one like that. Does the product description say it's a high pressure high volume regulator suitable for things like weed burners, tar pots, etc.? The one I've been using for about 30 years now looks a LOT like the one on "Propanewarehouse dot com" under mfg pt# MEGR-6120-30 Mine's a 0-20psi and it'll run six, 3/4" T burners no problem. Crank it up to 20psi and it'll start blowing my T burners out even running four. Frosty The Lucky.
May 24, 20179 yr It did say "high pressure"not sure if it was high volume, I think it said something about fish cookers and bbq grills. So if I read this right I am looking for a high pressure high volume Propane regulator, and I possibly can run 6 t-burners of the 3/4" type? I do want a regulator with a gauge,,, or I say I do. I see where your regulator has a port for a, gaugehttps://propanewarehouse.com/shop/propane-regulators/adjustable-propane-regulator-1-30-psi/ Thank you for the info. Edited May 24, 20179 yr by Allen Gaskill Finish idea
May 24, 20179 yr The pic of the regulator you link to LOOKS like the 0-20psi regulator I bought about 30 years ago and the one I own supplied 6 burners on a couple occasions. Fish cookers and BBQs don't require a lot of volume or pressure unless they're maybe commercial ones. Not knowing I'd buy a higher volume reg. I'd drive down to the Petrolane main store and buy one off the shelf and those look a LOT LIKE the one in the link. I don't know how much more clear I can make it but here goes. I can NOT evaluate a regulator by looking at the picture and have to hope psi and the description of light commercial uses means it'd supply what I need. A weed burner uses a SIMILAR volume of propane to a forge burner. I'd be rolling the dice buying online just like anybody. Maybe a good bet would be attend a local blacksmith club meeting and ask what they use and where they got it. Frosty The Lucky.
May 25, 20179 yr 36 minutes ago, Frosty said: The pic of the regulator you link to LOOKS like the 0-20psi regulator I bought about 30 years ago and the one I own supplied 6 burners on a couple occasions. Fish cookers and BBQs don't require a lot of volume or pressure unless they're maybe commercial ones. Not knowing I'd buy a higher volume reg. I'd drive down to the Petrolane main store and buy one off the shelf and those look a LOT LIKE the one in the link. I don't know how much more clear I can make it but here goes. I can NOT evaluate a regulator by looking at the picture and have to hope psi and the description of light commercial uses means it'd supply what I need. A weed burner uses a SIMILAR volume of propane to a forge burner. I'd be rolling the dice buying online just like anybody. Maybe a good bet would be attend a local blacksmith club meeting and ask what they use and where they got it. Frosty The Lucky. Thank You.
