Kevin Olson Posted April 15, 2017 Share Posted April 15, 2017 Going to shorten up the stump an inch. She left her mark :-) Thats only usage. No torch etc. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 15, 2017 Share Posted April 15, 2017 Could just rout and drop it back down there... Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted April 15, 2017 Share Posted April 15, 2017 Greetings Kevin, You might consider just using a router to drop the anvil just an inch. The set down into the anvil pattern works exceptionally well and you will only need a small bracket for a hold down. I have several that I have done this way. forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
bajajoaquin Posted April 18, 2017 Share Posted April 18, 2017 Kinda surprised nobody said "forge a chisel and then tap it out with that!" Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 18, 2017 Share Posted April 18, 2017 That stump could have a lot of slag and other metal in the wood that could tear up a cutting edge. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 18, 2017 Share Posted April 18, 2017 25 minutes ago, Glenn said: That stump could have a lot of slag and other metal in the wood that could tear up a cutting edge. Could always cut the inch off the bottom. Quote Link to comment Share on other sites More sharing options...
