BlasterJoe Posted April 5, 2017 Share Posted April 5, 2017 Made my first integral handle blade. The handle is temporary until I can get ahold of something better. It was made from a piece of leaf spring I found. Quenched in vegetable oil. Then did 2 cycles in the oven at 400degs. The spine is about 1/4 as wel as the handle. finish is rough but I am over all happy with it. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted April 5, 2017 Share Posted April 5, 2017 Nice shape. Well done. Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted April 5, 2017 Share Posted April 5, 2017 Good job! only thing I will recommend is to take a lighter to the end of the Para cord to stop the fraying. Littleblacksmith Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 5, 2017 Share Posted April 5, 2017 Or tie a knot and let the end fray as a tassel. Quote Link to comment Share on other sites More sharing options...
SLAG Posted April 6, 2017 Share Posted April 6, 2017 And you could knot the end and sew it shut to further avoid having the end unravel. You could use a thread that matches the cord color, or a contrasting color, or a colorless thread. SLAG. Quote Link to comment Share on other sites More sharing options...
gmbobnick Posted April 6, 2017 Share Posted April 6, 2017 One thing I have done is to wrap in a looped piece of light wire in the last 4 wraps of cord, leaving the loop-end of the wire sticking out, Now you can run the tag end of the cord thru the wire loop, then pull the wire out and tag end back under the wraps. If you measure right, the tag end will be buried under the wraps and protected. Nice clean strong looking knife! Quote Link to comment Share on other sites More sharing options...
BlasterJoe Posted April 12, 2017 Author Share Posted April 12, 2017 Went back and did a better wrap. Little more comfortable now. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted April 13, 2017 Share Posted April 13, 2017 How thick is it? I noticed that the bevel is only about halfway up the side. It looks like it will make a nice utility knife. Quote Link to comment Share on other sites More sharing options...
BlasterJoe Posted April 13, 2017 Author Share Posted April 13, 2017 The spine is a little over an eighth of an inch. The blade is 4 1/2 inches and 9 inches over all. It's pretty hefty. I've split some kindling with it and was still able to cut up an apple. Quote Link to comment Share on other sites More sharing options...
