Pancho07 Posted February 19, 2017 Share Posted February 19, 2017 Yesterday I came into possession of a canedy otto blower with stand and fire pot. I haven't had the chance to open up the gear box yet but I'm guessing that the oil has turned to tar. My question is is the a source for replacement parts if some of the gear teeth are broken or something like that? Also, what oil should I used in it once it's all cleaned and polished? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 19, 2017 Share Posted February 19, 2017 sources of parts? another blower of the exact same type or making your own Quote Link to comment Share on other sites More sharing options...
Kozzy Posted February 19, 2017 Share Posted February 19, 2017 Unfortunately, the diametral pitch and tooth count on gears has tended to be reduced to some standards whereas in the "good old days", a lot more options were available off the shelf. That can make some older gears hard to replace if they were a bit oddball. It is especially tough when you get into lesser used gears like the bevel gears sometimes used in post drills. But it's not time to worry yet. If it's only a tooth or two, even an unavailable gear can often be repaired by careful tooth build-up in either brass or steel (and hand filed to approximate shape). There are also metal build-up products that claim they are as strong as the parent metal (sort if like filled epoxies) but I hae no experience as to how true the claims are. The gears in a blower normally don't take huge loads so you can get away with less than perfect in many cases. Boston gear has some good references on their site regarding what gear nomenclature means and how to identify what you have. Their catalogs also tend to include what is the current industry standards so can get an idea of what's available in the broad marketplace without having to check 50 different catalogs. Gear pricing can be shocking, though, so I'm betting you will be doing a lot more research on the repair end before the replacement end (if they are even bad). Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 19, 2017 Share Posted February 19, 2017 Don't get carried away trying to polish the things, they weren't in the first place. They were in fact intended to be repaired in the shop or on the farm. After a few decades of mud dawbers, mice nests, rain and children crushing stuff in them they do tend to bet bound up. A soak in gasoline (white naptha in the day) or ATV and acetone will break the hardened oil loose. Then a trip to the pressure washer car wash and just blast the stuffins out of it. Why a car wash? Because they have pretty sophisticated oil traps in their drains to prevent pollution. As you're blasting it with HP water rattle the crank back and forth to help the crud break loose so the water can blow it out. Don't force ANYTHING, they're tough but not bullet proof. Still some vigorous back and forth on the crank while flushing it with water usually takes care of blockages. If it still won't turn or the impeller fan rubs, etc. THEN it's time to start thinking about taking it apart and guess what, cleaned out it'll come apart easier too. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Pancho07 Posted February 20, 2017 Author Share Posted February 20, 2017 Good news, the gear box was full of mud dawber blobs so that was easy to clean once I got the impeller off. Some of the shafts have a suprisingly light coat of rust so they are cleaning up pretty easily. What do I need to fill the gear box with? Same as my smaller champion? Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 20, 2017 Share Posted February 20, 2017 No, you only put a few drops of oil in the oil ports every now and then and it doesn't need to be anything special like nondetergent. Something a LITTLE sticky is good but not necessary and gear oil is a little much just like 3in1 is a little light. Still either will do, in the day there was no telling what was available I'll bet rendered bacon grease works a treat. However if you fill the case you'll find out how fast it will leak out on your floor. Do you REALLY need to ask me how I know. I know the gear box looks just like it has a level plug in the side, I don't know what it really is but fill it that high and it'll cover at least 10sq/ft of concrete shop floor in a nice even layer. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Pancho07 Posted February 20, 2017 Author Share Posted February 20, 2017 Perhaps "fill" was a strong word. It does have cast into the side of it something to the effect of "fill to level of air cock". I figured that I would maintain it the same as my smaller champion until I heard different so I guess I'll carry on. I didn't know if I needed to put some kind of gasket into it to prevent that or not, that would have been my next question. Quote Link to comment Share on other sites More sharing options...
Pancho07 Posted February 20, 2017 Author Share Posted February 20, 2017 Also, found it alittle surprising that one or two of the gears appear to be either wood or a similar density and texture plastic. I'm sure this isn't news to many but I hadn't encountered it before. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 20, 2017 Share Posted February 20, 2017 If it says to fill it to a mark that's what I'd do. My old Buffalo 400 doesn't have instructions on it it just leaks excess oil on the floor. No plastic in mine either but it's a different blower. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 20, 2017 Share Posted February 20, 2017 Some of the old equipment may have a "sacrificial gear"; so if something's going to break it will be *that* one and you only need to stock that one for parts. Unfortunately they are not stocked anywhere nowadays and tend to degrade over time---or to put it another way: Good Luck! (Murphy's Law also states that expensive and hard to make parts will sacrifice themselves to save the life of the cheap easily sourced sacrificial parts...) Quote Link to comment Share on other sites More sharing options...
Pancho07 Posted February 20, 2017 Author Share Posted February 20, 2017 I've gotten everything back together and oiled. Where do I need to adjust the crank to? Is it a personal preference or unit specific? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 20, 2017 Share Posted February 20, 2017 personal preference and task based. Quote Link to comment Share on other sites More sharing options...
SReynolds Posted April 10, 2017 Share Posted April 10, 2017 Yes. The Canedy Otto Royal Western Chief is an oil bath. Fill to the fill level cast directly onto the gear box i.e. the valve. Light oil. Adjust the crank arm to suit you. I have an all original which contains no wood, plastic, bamboo, saw dust and resin impregnated gears. Quote Link to comment Share on other sites More sharing options...
jtspain Posted October 28, 2017 Share Posted October 28, 2017 Ive been having issues with my blower as well, it's become entirely siezed up So, I recently got an old buffalo forge as a gift, all still in working condition, well the blower lasted maybe a week before it started to get harder to crank, I let it sit for a little while and now it will not crank at all, I don't know how to disassemble it, but I feel like that's the best place to start, it's a buffalo 200 silent blower, I'm not sure if it's rust or some bolts I'm not seeing, but I can't even get the gear case off Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 30, 2017 Share Posted October 30, 2017 see reply the other place you posted this on IFI. Quote Link to comment Share on other sites More sharing options...
crenick Posted December 17, 2017 Share Posted December 17, 2017 I recently bought this buffalo for $125. It cranked a little hard found out it hard hard grease in the gears. Cleaned it really good and now it turns very easy. It will crank 11/2 times after I let go. Very quiet too. It says Buffalo Forge but not sure of model. Quote Link to comment Share on other sites More sharing options...
Stash Posted December 17, 2017 Share Posted December 17, 2017 sometimes, if the stars are aligned properly, that is all it takes. Looks like a good one. Steve Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted December 18, 2017 Share Posted December 18, 2017 The Buffalo Silent 200 series is my favorite.. That is a later model with stamped steel fan case.. this model has the cast gear case so it's not the newest which has both a stamped gear case and a stamped fan case.. I prefer the cast iron gear case myself.. The last models had everything in stamped steel and the case got a little smaller.. As to the Cannedy Otto blowers they are filled up to the oil level drain and are a dry blower.. One of the only completely oil sealed blowers produced from day 2 of production. the Gear case gets filled with a light oil up to the drain.. There is also a hole in the crank handle boss that gets a drop here and there.. I own 6 Buffalo silent 200s ranging from late 1800'd to about 1910 with 1 a later unit from around 1930.. They range in Model size from 12" with 14" being the most widely produced size.. They also produced a 16" model for 2 years and then it became a special order item at a premium price.. Right round this time frame they switched from a double roller radial bearing (Magneto bearing) to a setup more like a ring and pinion the the bearing only on one side of the spur gear.. I prefer the models with both sides of the spur gear with bearings.. The years of production of the Buffalo blowers is funny because what they used for a size reference is beyond me as there is not one measurment that means anything.. The 12" doesn't measure 12", the 14" has the same case and fan case as the 12" with a larger fan blade.. The 16" is huge in comparision but its really only like 14".. I also own a Cannedy Otto Western Chief which is one of the highest quality blowers made and again.. Does not leak oil.. Every other blower maker Champion, Buffalo, etc, etc. are all oil leakers.. I've been looking in a way to put oil seals into the buffalos to stop them from leaking.. Eventually I'll post my findings.. Quote Link to comment Share on other sites More sharing options...
