Ijimmyzw22 Posted December 6, 2016 Share Posted December 6, 2016 After building my propane forge and dialing it in this is my second knife. I think it came out good but I'm no expert by a long shot. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted December 6, 2016 Share Posted December 6, 2016 howd you make the holes in the knuckle guard? cool design. think the sharpened curve after the blade might have been better dull. just an opinion. lil more finish work could help too. just the opinion of a non knife maker that likes blades. Quote Link to comment Share on other sites More sharing options...
swedgemon Posted December 6, 2016 Share Posted December 6, 2016 Looks good !! What steel did you use and what handle material ?? Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted December 6, 2016 Share Posted December 6, 2016 as far as looks go, you did a pretty good job for a second knife. if i'm seeing it right it looks like your bevel is only 3/8 in. or so wide, which is pretty narrow .... how did you heat treat it? Quote Link to comment Share on other sites More sharing options...
swedgemon Posted December 6, 2016 Share Posted December 6, 2016 We could use a pic or two of your forge, when you get to it !! Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 6, 2016 Share Posted December 6, 2016 Two small details: first, like Daswulf, I'd recommend a higher finish, especially around the finger holes. Any rough or sharp(ish) edges there will definitely mess up your fingers. Second, the choil (what Das calls "the curve behind the blade") is awfully deep and could be creating a weak spot between blade and handle. A blade that big invites heavy use (chopping and the like), and the narrow area above the choil might not be robust enough to take the punishment. Quote Link to comment Share on other sites More sharing options...
TheoRockNazz Posted December 7, 2016 Share Posted December 7, 2016 WOW! That is a great second knife, you should be proud. Makes me think the Counter Strike games for some reason. I agree that the finger holes could probably be softened a bit, but if it's for yourself you will be the best judge of how much. Doesn't hurt to try using it... unless it literally hurts, in which case you'll have a lot of sanding to do, haha If you filed in the deep jimping before HT it might spell trouble with that deep belly/choil - stress risers love places like those. Quote Link to comment Share on other sites More sharing options...
Ijimmyzw22 Posted December 7, 2016 Author Share Posted December 7, 2016 Thanks for the input guys I need it. The finger holes look sharper than they are they are well rounded and it is very comfortable in the hand. I used some high carbon steel I had in scrap. Heat treated with motor oil and a quart of trans fluid and yes it did warp a tiny bit at the Chou as you call it. The wood is just some poplar I had laying around. The shallow bevel is because I just didn't know how deep to go. OverAll it's very sharp and very comfortable in my hand. I'll keep taking all the helping pointers I can get. Starting a skinner knife tonight. Her is a pick of my forge. 10 inch square by 18 inches. I tug welded from flat steel. 2 inches of ceramic wool then lightweight firebricks inside. Oh and my first knife. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted December 7, 2016 Share Posted December 7, 2016 Nice! One piece of advice from someone that likes knifemaking but hasn't started yet but has researched a lil. Get quality stabalized handle material. It will do you good, start out right. I think you are well on your way. Get the right material to do the job. Quenchant, steel, handle material. Go all in and see what you can turn out. Good starter pieces. Just for what it's worth. Quote Link to comment Share on other sites More sharing options...
