Any idea as to maker
Any idea as to maker or any other data about it
its cast, it weighs 75 pounds, there are many here who can tell you the maker by the recess in the base
Thanks for the reply - hope someone can help with the identiy
Are there any markings on the sides of the body or maybe the front foot? How is the rebound on it?
I actually am picking it up tomorrow and will know more .... It is heavier than a lot of cast anvils I see out there and it doesn't have a really short horn, like cheap cast anvils.
I'm hoping that it isn't a really cheap cast ... or (dare I hope) cast steel and not cast iron.
If that anvil was used for forging on it and survived in such a good condition it might be a good if not excellent anvil. Also it's so well made, so clean, unlike the  usual ASO counterfeits. So it might be an excellent anvil or an outstanding ASO
I reckon you could easily have a hardy and pritchel hole water jet cut if it does turn out to be a decent anvil.
All the best
Andy
I read about the 'rebound' steel ball - method of testing hardness.  I took a 1" steel ball bearing and dropped without 'throwing' the ball from 10" ... the rebound was about 4.5" on average ... I am convinced that this little anvil is not a door-stop (ASO) cast iron ...
It does have several straight line 'cuts' in the face which look like cold chisel marks.
I took a wire brush to it and gave it two coats of black paint ... I'll take some photos of it tomorrow.
Bearing ball dropped from 10", rebounds 4.5" for a 45% rebound, that's poor and backed up by chisel cuts across the face doesn't say anything BUT ASO. Did the 1" ball leave dents? Results like these are exactly why you should test before buying, not after.
1/2" bearing balls will tell you the same thing just as effectively and you can carry one around in your pocket all the time. A light scratch with the back of the point on a pocket knife blade is another decent test if you don't mind doing that to your knife.
Don't toss it, it's still useful even as an anvil just make sure you're hammering HOT steel, keep it in the high orange and you'll be able to make enough marketable product to save and buy a better anvil. We've all been there in one form or another or we wouldn't be human or have a bunch of . . . stuff collecting dust around the shop.
No - no dents.  no dents from the round end of a ball peen hammer either.
The same  drop on the from the same height on the rail road iron yields the same results (and only a slightly better 'ring')
Greetings Eagle,
.    Years ago I bought an anvil at a tractor show and put it in the pile with others ... Mr. Postman wrote in his book that the Enders company only made small cast anvils about 8 Pounds.. Just to have fun I brought my Enders 150 pound anvil to SOFA and displayed it on my tailgate . Richard a friend soon found me and he ended up with it .. We established that it was a prototype and was never produced for sale.. I think you might have the same situation with yours. Have fun
Jim
A rebound test isn't very relevant where rail anvils are concerned the % will vary wildly depending on whether the rail is laying flat or on end.
Did you test it before or after removing the rust from the face? Because the rust or paint will cut a lot of % of the rebound. Also you can check the hardness with a file - it must rather skate than bite (depends of the hardness, good anv8ls may have from  ~50 to over 60HRC), if bites in like on soft steel it's either not hardened or it's cast iron. It could be also told if it's steel or cast iron by the spark test with a angle grinder.
