June 14, 201610 yr This workbench along with a vise turned up on a local auction website. The listing says it's a Record #52 vise. Nobody has bid on it, and I was wondering if the vise is worth anything?
June 14, 201610 yr $1.50 to $150, depending on who wants it, and what they intend to do with it. Bench looks solid, if begrimed with paint and glue. Does the bench come with it?
June 14, 201610 yr Author I didn't know it was for wood working... That's a bummer. Perhaps I will still get it if no one else bids. And yes, the bench comes with it and also two pipe clamps.
June 14, 201610 yr My grandfather has a similar its awesome to hold wood so you can chisel notches in it on projects....
June 14, 201610 yr I have an old vise somewhat like it save that mine has a piece that can be raised up in the middle of the moving jaw allowing you to hold long/wide pieces by using bench dogs
June 14, 201610 yr It's a good woodworker's vice and "worth" $ 20 to $ 40 depending on location but it's tied to a boat anchor that'd cost most people more hassle in moving (and/or disposing) than the vice is worth. I'd hand you $ 25 for the vice right now (unless the photos distort the size and it's one of the small ones) if there was no shipping involved. Records are good woodworker vices.
June 14, 201610 yr One of the nice features of this vice is the "quick release" lever, just to the right of the screw. Pull that up to disengage the nut, and you can slide the vise open with one hand. Put in your workpiece, slide the vise shut, give the handle a half-turn, and you're good to go.
June 14, 201610 yr Record is a decent if mediocre brand. Quick release woodworkers vises are 5 times more convenient than non-quick release models.
June 16, 201610 yr I would say record is better than a mediocre brand. They are one of the better woodworkers vise of this type, good quality casting and made of good steel. I think they stopped production a few years ago, but just like machinist vices, these are better than the made in xxxxx crap you will find today at the big box store. I see these going for $40 to $50 used pretty often. I've had mine taking abuse for about 15 years and it is still going strong. just attach two wood cheeks to it where they provide screw holes for that purpose. update: it seems Irwin bought the tooling and brand about 10-12 years ago and is making them now in taiwan. the british made ones are very good and if you can pick a 52 or 53 up cheap, go for it.
