Benton Frisse Posted April 13, 2016 Share Posted April 13, 2016 Here's my first wood chisel. I wanted to do a style like Gerald Boggs but I don't have the best equipment/skill to forge shoulders, so I decided to do a socket style. Mild steel socket and body, 5160 forgewelded onto the bottom for edge, and a sycamore handle. I have some trouble with forging sockets and not getting a slight gap or space where they'll meet the body, whether or not it's on a chisel or an arrowhead. I have trouble getting a completely wrapped, no gap socket. Any tips or suggestions? I chose sycamore because i've been told it makes good hammer handles and is nice and hard, so I thought I'd give it a whirl. Heat treat was quenched in warm, used motor oil and baked at 425F for an hour and a half. Thanks! Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 13, 2016 Share Posted April 13, 2016 Looks pretty good to me. I make sockets overlap a little and saw them even. How's it work? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Benton Frisse Posted April 15, 2016 Author Share Posted April 15, 2016 On 4/13/2016 at 4:07 PM, Gerald Boggs said: Looks pretty nice to me. On the socket, tell us the sequence you did it. HI Mr. Boggs, loved your demo in the Anvils Ring, that was what inspired me to try! I started with half inch round stock, upset it to about 5/8 or 3/4 and flattened it on the edge of the anvil, much like a socket for bodkin/medieval arrowheads. Rolled and rounded it between the step and the anvil face with a ballpeen. I worked the neck where the solid stock meets the socket with a cross and ball peen to try to thin and smooth it out. Then drew the blade part out flat to my desired width, grabbed some 5160 and matched the width, drew it a bit longer. For the weld, I laid the body on top of the carbon steel, folded a lip over the end to secure it, then heated 'er up and welded it. Then I forge welded the socket closed, too. Ground, hardened in used motor oil, set my tempering oven to 425, stuck it in and came back an hour later. Mr. Boggs, when you fit the ring on the end of your handle of your chisel, do you hot fit it? On 4/13/2016 at 4:49 PM, Frosty said: Looks pretty good to me. I make sockets overlap a little and saw them even. How's it work? Frosty The Lucky. Frosty, it shaves curls beautifully! Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 15, 2016 Share Posted April 15, 2016 Very nice. With that cranked handle, this is for paring, yes? You might want to try beveling the edges to give you better clearance when paring, for example, the shoulder of a tenon or between the tails of a dovetail joint. Quote Link to comment Share on other sites More sharing options...
Benton Frisse Posted April 25, 2016 Author Share Posted April 25, 2016 On 4/15/2016 at 0:48 PM, JHCC said: Very nice. With that cranked handle, this is for paring, yes? You might want to try beveling the edges to give you better clearance when paring, for example, the shoulder of a tenon or between the tails of a dovetail joint. Hey JHCC, I'll give it a whirl, thank you! This was intending to be just a standard chisel for wood work. I need to do more research on the different types of chisels. On 4/15/2016 at 0:53 PM, Gerald Boggs said: It sounds like you've got it, you might try doing the finishing of the neck with a rounding hammer and the horn. It makes the closing up of the socket go easy. I'd tried to link to a video by Hector Cole forging a War Bodkin. Watching that is were I learned to forge sockets. Anyway, here's a link to his main YouTube page: https://www.youtube.com/channel/UCHyke42e_ycEucIa5bSXrMw Thank you for the link, Mr. Boggs! I'll give the rounder and horn technique a try. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 26, 2016 Share Posted April 26, 2016 6 hours ago, Benton Frisse said: I need to do more research on the different types of chisels. This link might be a good place to start. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 26, 2016 Share Posted April 26, 2016 Weygers has a whole chapter on making wood carving gouges in "the Complete Modern Blacksmith" It also contains some pictures of the sculptures he's done with them....durn polymath! Quote Link to comment Share on other sites More sharing options...
