Randolph_ar Posted March 30, 2016 Share Posted March 30, 2016 Hello All, this is my first post in IFI. I would like to say that I have enjoyed reading through the forum this far. I recently started to try my hand at making knives by stock removal. Now I have decided that I wanted to try forging some knives. My father-in-law gave me an anvil, and that got it started. I had built a small forge that I run charcoal on to HT my knives, but it wasn't big enough to do real work with. So I watch some YouTube videos and read on here, and settled on a design. I still want to make a clinker breaker, but just have got around to it yet. I am currently using a piece of angle iron that I bent into a U shape stuffed into the air outlet. The forge is made out of an old brake from a truck, and the table is 1/4" thick sheet that is about 2'x3'. The hood is 1'x2' and 1' tall at the opening. I put a 2" pipe union on the bottom to facilitate easier removal of the air and ash dump piping. The air is being provided from a hair dryer with a rheostat. I was pleasantly surprised at how I was able to control the air to the fire with it. I need to tie the hood into the duct work for my wood burning stove. The two will live side by side in my shop. Anyways, let me know what you think. I look forward to making some knives and other things with it. Quote Link to comment Share on other sites More sharing options...
natenaaron Posted March 30, 2016 Share Posted March 30, 2016 Welcome Randolph. I don't know anything about coal forges but the set up looks good. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted March 30, 2016 Share Posted March 30, 2016 bad idea to tie wood burning stove with forge flues. Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 30, 2016 Share Posted March 30, 2016 2 hours ago, Steve Sells said: bad idea to tie wood burning stove with forge flues. Risk of igniting creosote? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted March 30, 2016 Share Posted March 30, 2016 draft problems, covered in the chimney/flue section Quote Link to comment Share on other sites More sharing options...
Randolph_ar Posted March 30, 2016 Author Share Posted March 30, 2016 2 hours ago, Steve Sells said: draft problems, covered in the chimney/flue section I just got done running the forge after finishing up the flue. I did not see your post about it being a bad idea until now. I put in a damper to block off the forge when burning the wood stove and I already had a damper on the wood stove. I was pleasantly surprised at how well it worked. I will look up the issues you talk about in the chimney/flue section. I haven't looked through that section yet. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 31, 2016 Share Posted March 31, 2016 Coal fires soot the flue where wood creosotes it. Combined they're chimney napalm, lights easy, burns really HOT and very hard to put out. Don't combine the two at best you'll void your insurance. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
turbo7 Posted March 31, 2016 Share Posted March 31, 2016 1 hour ago, Frosty said: Coal fires soot the flue where wood creosotes it. Combined they're chimney napalm, lights easy, burns really HOT and very hard to put out. Don't combine the two at best you'll void your insurance. Frosty The Lucky. Admin, This might make a good stickie in the Chimney/Flue section? Quote Link to comment Share on other sites More sharing options...
