January 18, 201610 yr Yes Josh I like this! What material do you use for it? Looks like sheet steel. Well done looks great.
January 18, 201610 yr Author Thanks guys! I used bar stock for the arms, probably like 5/16 or something, and I used 16g sheet for the head. Originally, I tried to raise it in one piece, but I was working really fast, and I guess I probably had a rich flame (or is it lean? Whichever one has too much air) and I lost a lot to scale, so once I got it to shape, it was too thin to behave. So I just welded up a little can, ground off the welds and knocked in the corners. I ended up making a punch for the eyes. Not sure if I'll ever find another occasion to use my octopus eye punch.
January 18, 201610 yr Steel at forging heat will scale in open air regardless of the forge. Unless it was scaling IN the forge you just ran into normalness. Sheet seems to scale a lot faster but it cools so much faster it's in and out of the forge a lot more often. Frosty The Lucky.
January 18, 201610 yr Nicely executed. Immediate thought was how that design could be "adapted" to make an attractive coat hanger for the right setting, nautical themed pub or sea food restaurant maybe!
January 19, 201610 yr Nice. Love the colour. FYI Google: "Leigh Dyer Hastings octopus". A local steel sculptor.
