December 15, 201510 yr Has anyone tried any kind of anti-rust coating (OTHER THAN OIL) on your non stainless knives? If so what and how is it applied?
December 15, 201510 yr The higher polish on the finish, the more resistance to rust starting, then wax/oil regularly
December 16, 201510 yr Author 7 hours ago, otto said: I like to use horseradish to patina blade. Seems to not rust so far. Otto if you would, describe the process a little, unless you are yanking my chain, I am interested.
December 16, 201510 yr Variation on the mustard patina, which you should be able to find in a search. Think of how the old high carbon steel cooking knives blades looked after long use.
December 16, 201510 yr Author 1 hour ago, ThomasPowers said: Variation on the mustard patina, which you should be able to find in a search. Think of how the old high carbon steel cooking knives blades looked after long use. Yeah I found some info on forced Patina. I will give it a try...Thanks
December 17, 201510 yr The horseradish patina is easy. I do it on some of the knifes I make. You polish the steel up a bit then you dab the horseradish on the bare steel. Leave it on for 10 minutes wash it off with water. Do this a few times. I usually do it 4 to 5 times for a knife. It will give a dark patina like an old carbon steel kitchen knife. I read about it in the 50$ knife shop book. He also said he uses mustard. I have not tried the mustard myself though.
December 22, 201510 yr Author 20 hours ago, tompdw said: I use car wax. I know a couple of guys who use car wax on their carry pistols to prevent rust. I actually thought of trying it, now I may...Thanks
December 22, 201510 yr I usually use renessaince wax on everything from tip to butt. Always a nice luster then. If it is going to a new home I use either beeswax and give them a small piece so they can clean and wax it themselves.
December 22, 201510 yr Author I like Beeswax, I use it in leather crafting and in making bowstrings. So you just rub in on and buff it in I guess. No heating?
