Making a RR track base
Fuggin "Forbidden" ..... :angry::angry:
With the Rail standing on end, ... a 15" long piece of 2" Angle, ... with holes at the ends, ... welded on the end of the Rail, to form an upside-down "T", ... and another 3" long bit, welded to what was originally the "top" of the Rail, ... yields a stable "3-point" base, ... that can then be Lagged to any kind of wooden base.
Edited by SmoothBore
  • 2 weeks later...
Got base made. I tried to drill but went through three drill bits and didn't scratch the surface. Even used oil on the drills. So to attach to base was thinking to use lags and washers washer actually securing the rail to the wood.  Also ratchet strap bottom. Any other suggestions
Do you have a torch? You can simply torch bolt holes OR heat the spots you wish to drill to black heat and let them air cool. Using a carbide drill bit might do it but any chatter will kill expensive bits.
Your idea to use washers on screws outside the flange will work just fine. If you were to drill a couple holes in a couple pieces of say 1/4"x1 1/2" strap to act like you envision for the washer it'll be more secure.
