July 1, 201511 yr I've been reading up on patina for 5160, and I've seen several things suggested. I'm chopping up a partially finished 5160 greatsword to make a few hunting knives. I'm looking for a deep gray, almost black, that will stand up well to use for things like cutting brush, and even light chopping on a HT blade. Most often I've seen vinegar soak, PCB etchant, and gun bluing suggested for dark patinas. I've also found that gun blue won't work on some tougher steels and most stainless. Do you have any experience with a patina on 5160? What is your favorite? Why?
July 1, 201511 yr Just send them to me, any that survive my destructive "testing" will have a nice dark patina ;-) I would think that gun bueing would give you the most consistant results. The steel you are using isnt particularly exotic. As to durability? Yeah right. The only thing that holds up is the patina that comes with age and use. Edited July 1, 201511 yr by Charles R. Stevens
July 1, 201511 yr I was thinking that the old fashioned rust bluing would be a method. I have a copy of an old book on firearm bluing and browning that I'll try to remember to add to this thread after today's 14 hour workday is over.
July 1, 201511 yr If you want black, "Parkerize" it. Phosphoric acid leaves a nice BLACK phosphoric oxide finish. Follow with oil or wax sealant. I believe you can sand or rub the phosphoric oxide patina down for various degrees between black and steel before sealing.Frosty The Lucky.
July 2, 201511 yr Author If you want black, "Parkerize" it. Phosphoric acid leaves a nice BLACK phosphoric oxide finish. Follow with oil or wax sealant. I believe you can sand or rub the phosphoric oxide patina down for various degrees between black and steel before sealing.Frosty The Lucky.I generally heat my stuff to 250F before I oil it. This may be a dumb question, but will the heat effect a phosphoric patina?
July 2, 201511 yr Author Also what do you guys think of making your own Parkerizing solution? I found this recipe online, but from what I've read about parkerization, it's a pretty toxic and dangerous process. Thoughts?
July 2, 201511 yr I probably misspoke calling phosphoric acid patina "Parkerizing." Phosphoric acid is inherently dangerous stuff like any strong acid you MUST wear PPE and use proper equipment. It's especially dangerous if spilled on concrete the reaction can be very violent. It's maybe a better idea to use a formula and process laid out by pros.I'm thinking Thomas's recommendation of the book on bluing is a better bet than recipes listed by some guy on the internet.I believe, "I saw a guy on the internet do this." will join the famous last words like, "hold my beer, watch this," before long.Frosty The Lucky. Edited July 2, 201511 yr by Frosty
August 14, 201510 yr Hahaha frosty I've heard and seen the results of hold my beer, and watch this way to many times lol
August 14, 201510 yr Hahaha frosty I've heard and seen the results of hold my beer, and watch this way to many times lolYeah, life is full of lessons, I just try not to learn directly. About holding your beer. Your Avatar looks like someone with his/er head on fire, that isn't a picture of you is it? I can spit fire, hold my beer, watch THIS!Frosty The Lucky.
August 14, 201510 yr lol no it's HephaestusWhat fun's that? Couldn't you have at least made up something to amaze and amuse us? Don't tell me I have to explain the whole blacksmithing and Bull Shooting abbreviation thing?Frosty The Lucky.
