angiolino Posted November 30, 2014 Share Posted November 30, 2014 hello we have to realize for a house in the countryside a shed or pergola or patio to be fixed to the wall and then place an iron portal measurements are 20 feet long high 11 ffet larga13 feet iron one hand resting and hooked to the wall of the house from 'backed up to a portal formed by two pillars iron uprights and a beam iron might help size the various parts and materials required have a drill welding and grinding machine thanks Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted November 30, 2014 Share Posted November 30, 2014 Bolting is always nice as it allows for removal later if needed. Bolting also doesn't create a possible fire hazard that welding does. Do you have a picture of what you are doing? Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 3, 2014 Share Posted December 3, 2014 Bolting allows movement between the addition and the house. Unless you're going to connect all adjoining walls and foundation solidly they will move differently and cause damage. So unless you're going to make them one piece bolt them together. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
angiolino Posted December 17, 2014 Author Share Posted December 17, 2014 # hello I have to build an outdoor canopy type patio that serves as protection for the front door and canopy for the car measures sono.lunghezza L = 15 feet, width = 10 feet, height = 11.5 feet in iron, from a i want to side with iron plates bolted to the wall on the other side i want to support the joists to a girder resting on two iron pillars type portal that advice you can give me what material to use that section with aspect information and suggestions hello Quote Link to comment Share on other sites More sharing options...
angiolino Posted December 17, 2014 Author Share Posted December 17, 2014 Sorry guys but I do not speak English and I have difficulties to insert pictures and drawings I would need tips and sorry if I postat 2 messages sequentially aspect grazi tips for your patience and your precious time is a patio sun to achieve iron frame transparent cover polycarbonate 16 mm Quote Link to comment Share on other sites More sharing options...
turbo7 Posted December 17, 2014 Share Posted December 17, 2014 bolt it mate Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted December 17, 2014 Share Posted December 17, 2014 I would agree with bolting. Take extrordinary care in flashing and make certain you bolt to either the header or uprights, not the skin of the existing building. As to structural size, shape, weight and spacing dictate size of members. Typicaly what looks good is significantly overbuilt for steel (if your used to looking at wood or stone) what steel profiles are avalable to you and what is esteticaly pleasing? 14.75m would be closer to 48' Quote Link to comment Share on other sites More sharing options...
angiolino Posted January 14, 2015 Author Share Posted January 14, 2015 thank you for your valuable record Quote Link to comment Share on other sites More sharing options...
