Show me your anvil tools
Glenn
Show me the tools and tooling you use at your anvil. It can be an anvil tool, hardie tool, prichel tool, bottom tool or top tool, etc, just as long as there is an anvil involved.
A spring fuller
Drop it into the hardie hole and put the hot stock between the ends of the fuller and hit the top of the fuller to leave a depression in the metal.
Greetings All,
I have many , many,  I thought I would pass a few on for your inspection..   This one is simple .. It is a adjustable pipe style clamp welded to a base with a hoop and wedge hardie hold fast..  An anvil stock hold down that's adjustable ..  Works well for sheet and other stock..  For odd shapes like leaves and stems just form a small steel hoop with a flat .   Have fun
Jim
post-30666-0-13552100-1385411423_thumb.j            post-30666-0-54413300-1385411461_thumb.j
Greetings again,
This is a side mounted bending fork with a hoop and wedge hold fast style hardie.  I have many that are set at different widths .  They are great for some special bending jobs.  I use them a lot on the anvil top for setting down leaves and round bar hold fixtures.   Lots of uses yet to discover.. Have fun
Jim
post-30666-0-61241800-1385412855_thumb.j      post-30666-0-91987400-1385412937_thumb.j
Greetings again/again
Last one for the day...   This is an anvil jig that's easy to make that holds with a clamp long stock for anvil face work..  I also use it for edge work.  It comes in handy for all sorts of hard to hold projects..   Enjoy
Jim
post-30666-0-86427900-1385426569_thumb.j     post-30666-0-19132300-1385426615_thumb.j
post-30666-0-28828500-1385426655_thumb.j
Here's my spring loaded hold down. Its a 6.5in piece of cast iron plate which I drilled and tapped to take 3/8in all thread. The all tread can be inserted in any of the holes depending on the size of the material to be held down. The bottom of the plate is scored so it can be used as a stand alone hold down by just turning the plate 90 degrees. The center bolt has a square nut on the underside of the plate to hold it in position when you are using it so it won't allow the piece being held down to move.
post-25611-0-75562600-1385669815_thumb.j
post-25611-0-95488300-1385669824_thumb.j
post-25611-0-18384000-1385669840_thumb.j
post-25611-0-84322000-1385669864_thumb.j
