Dee J Posted September 26, 2013 Share Posted September 26, 2013 Greetings all. I'm an amateur blacksmith based on the western edge of Dartmoor. I've got a small hand-cracked side-blast forge which I currently fuel with lumpwood charcoal. Typically forging small stock (8-15mm) into garden, household and tool items - just for our own use and amusement. I'm looking for other fuel options, both local bulk charcoal and coal or coke. What's available locally that any of you would recommend? Cordialement Dee Quote Link to comment Share on other sites More sharing options...
GNJC Posted September 26, 2013 Share Posted September 26, 2013 I started out with a hand cranked forge, it was pretty hard work with coke, not so bad with coal, well easier to keep alight but far more smokey. Dave Budd and John B are both pretty close to you and should be able to advise about the best suppliers in your area. If you have access to hardwood and can get a whole oil drum you could make your own charcoal... once you've done it a few times you should be able to produce decent stuff. Quote Link to comment Share on other sites More sharing options...
John B Posted September 26, 2013 Share Posted September 26, 2013 Hi Dee, if you are able to, come along to the Forge in at Exeter this coming weekend and you can see/try the coke we use, and have a play on the forge hearths, or just watch others demoing and working. Ordinary household coal will work in a hand cranked forge/hearth, just have to learn the best way to manage that particular type and grade of coal you are using, some are better than others. If you can't get along, we purchase our fuel from Symonds at Clannaboro near Bow, or you could try Jeffries at Bovey Tracey Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 26, 2013 Share Posted September 26, 2013 Dave Budd and John B on here are the people to ask, im a long way away in the east mids and use forge breeze from KG Smith near northampton Quote Link to comment Share on other sites More sharing options...
Dee J Posted September 27, 2013 Author Share Posted September 27, 2013 Thanks all. Sorry can't make Exeter this weekend. Dee Quote Link to comment Share on other sites More sharing options...
tamglasgow Posted December 18, 2013 Share Posted December 18, 2013 Does any one know a reliable source of solid fuel in scotland, i usually use coke but i might try coal. Also, are there varying qualities? does it range from place to place? thanks Tam.x Quote Link to comment Share on other sites More sharing options...
Dave Budd Posted December 18, 2013 Share Posted December 18, 2013 I must've missed this thread first time around, sorry Dee J! Dee, I get my coke from Jeffries most of the time (though they are now called Northover Fuels). The nice man delivers around the fringes of dartmoor frequently if you don't want to go down there for a few bags. Like GNCG says, coke is hard work on a hand crank, but charcoal is easy and some folk will mix charcoal with coke to allow it to work more easily. I buy a lot of charcoal from a chap in Somerset for use with my teaching forges and demo set up. If you are after smaller amounts (I buy several hundred Kg at a time) then there may be coppice workers nearby making some to sell and of course supermarkets/Jeffries sell imported stuff (its hard and unpleasent, but much cheaper than good local fuel). I may be able to supply you with small amounts too, assuming its only the odd 20kg here or there, but check out local green wood workers first. Tam, no idea about sources of coke in Scotland I'm afraid,but I would suggest phoning your local coal merchants and seeing what they have. Also call any nearby smiths and see where they buy from ;) As to different types and quality, its all pretty crap these days! Coal, I've not much experience with since I can get charcoal, coke and propane so eaily Quote Link to comment Share on other sites More sharing options...
John B Posted December 21, 2013 Share Posted December 21, 2013 Try Chris Topp for UK deliveries, competitive rates, I am told it is good stuff and produces little clinker. May be worth a try. Quote Link to comment Share on other sites More sharing options...
basher Posted December 22, 2013 Share Posted December 22, 2013 Chris Topp is quite expensive. KG smith is a lot cheaper and will deliver uk wide.... it may be that the Topp fuel is better quality though. Quote Link to comment Share on other sites More sharing options...
GNJC Posted December 22, 2013 Share Posted December 22, 2013 I haven't bought any of K G Smith's coke for a long time, it was causing a foul sticky, spongey clinker that made working very difficult. Is that problem now solved? Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted December 24, 2013 Share Posted December 24, 2013 I dont have anything to compare it with but have no problems Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted May 23, 2015 Share Posted May 23, 2015 (edited) Does any one know a reliable source of solid fuel in scotland, i usually use coke but i might try coal. Also, are there varying qualities? does it range from place to place?thanksTam.xTam Did you manage to find a coal supplier?I found a supplier when i move home. £295 40*25kg bags. This is for bituminous house coal.Anyone know if this is a good deal?https://www.coaldelivery.co.uk/fuel-categories/House-coal/British-House-Coal/?gclid=Cj0KEQjwyoCrBRCl-aa97pKX_t8BEiQAbrs_9GM3scBdKqHg7M2kRw17LXsfqh07ldKLCGMF2uNaLh0aAkvP8P8HAQ Edited May 23, 2015 by Stephen Jones added a bit Quote Link to comment Share on other sites More sharing options...
tomfromuk Posted May 23, 2015 Share Posted May 23, 2015 Seems reasonably priced for regular house coal, probably worth getting one 20kg bag 1st and trying it out, unless you burn alot of coal on house fires. Where abouts its scotland are you moving too? There is a company in the borders called pearsons of duns who do various types of bituminous and anthracite coal. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted May 24, 2015 Share Posted May 24, 2015 Ill be in west lothian about 20 miles from edinburgh and 25 from glasgow so im pretty good for city stuff Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 24, 2015 Share Posted May 24, 2015 I've read reference to smithing using peat historically or for the modern masochist... Quote Link to comment Share on other sites More sharing options...
Dan P. Posted May 26, 2015 Share Posted May 26, 2015 (edited) Peat is useless.I've used Scottish coal, bought it from Bengry's (Herefordshire), I think I remember that they told me it was the only coal being mined in the UK (??). It was pretty horrible for forging, but maybe it was just too big. Coal seems to work a lot better when in beans (bingles?) size.Bengry's coke is fine. Big horrible clinkers, but that's coke for you. I've yet to come across the mythological "unicorn coke" that doesn't have big clinkers.For the hobbyist with a hand-cranked forge I would recommend small coal size mixed with charcoal. Lumpwood charcoal with just whatever house coal you get locally. You would go mad worrying about finding "the best" coal. Or use propane. Edited May 26, 2015 by Dan P. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 23, 2015 Share Posted September 23, 2015 Found a cheaper supply http://www.nationalcoal.co.uk/buy-coal-from-national-coal/coal/pet-coke-doubles 290 for 40*25kg pet doubles Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 23, 2015 Share Posted September 23, 2015 have you tried this?looks a bit large to me and the coke I use goes out as soon as you turn off the air so only burns in the middle, this looks like it may burn all over and need to be used differently like charcoal maybe Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 23, 2015 Share Posted September 23, 2015 not yet I only listed it as i noticed it was cheaper than the last one i posted. The only down side to this is that they ask for a minimum of 1 tonne per order.. thats a lot of coke to burn through. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 23, 2015 Share Posted September 23, 2015 and if it is not useful that is a lot Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 28, 2015 Share Posted September 28, 2015 I contacted them SJ, it does not sound suitable but they will get the right stuff if you want 30 tons Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 20, 2015 Share Posted October 20, 2015 ID Ill pass on the 30 tonnes.. Though at this rate you might get another visit when I have to drive to englandshire to get some. Quote Link to comment Share on other sites More sharing options...
