jmhlsy Posted August 31, 2013 Share Posted August 31, 2013 I am in process of first forge build. Only part I can not source is the Ward 1-1/4 x 3/4 x 1-1/4 reducing tee. I checked with local industrial pipe supply and plumbing supply house, neither had or could get. Where is this part available? I have seen a few online but none look very smooth in transition like the ones on Zoller. Thanks Quote Link to comment Share on other sites More sharing options...
jeremy k Posted August 31, 2013 Share Posted August 31, 2013 Very simple - Contact Zoeller about them. Quote Link to comment Share on other sites More sharing options...
jmhlsy Posted August 31, 2013 Author Share Posted August 31, 2013 Thanks, might have to do that but was trying to source locally. Of course that's not looking good. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 31, 2013 Share Posted August 31, 2013 not all places have imperial measurements either. so depending on where local is too you, you may not be able to get it, where are you?> Quote Link to comment Share on other sites More sharing options...
jmhlsy Posted August 31, 2013 Author Share Posted August 31, 2013 North Georgia Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 31, 2013 Share Posted August 31, 2013 iirc, 3/4 is for the burner tube, if you cant get 1.25 , then try 1.5 for the tee.... look at a local big box store Quote Link to comment Share on other sites More sharing options...
DSW Posted August 31, 2013 Share Posted August 31, 2013 It took me 2 or 3 tries before I found them at a local plumbing supply. My normal supplier of plumbing parts had them listed in the system, but only had the cheap import ones in stock. We ordered one of the Ward ones and when it came in, the main warehouse had shipped out one of the imports instead. We ordered a 2nd one from another store, only to end up with the same result. The next place I tried also just stocked the standard import ones. I then tried another local supplier who wasn't as convenient and they had them in stock. Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 31, 2013 Share Posted August 31, 2013 I use 3/4"x1"x1" in mine and they'll melt the fire brick in the floor if I leave them turned up too long. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted August 31, 2013 Share Posted August 31, 2013 Ward fittings are primarily used in the fire sprinkler industry. www.hightemptools.com sell them. Tell Wayne that Wayne Coe sent you. Quote Link to comment Share on other sites More sharing options...
macbruce Posted September 1, 2013 Share Posted September 1, 2013 Here's this......http://www.mcmaster.com/#44605K356 Quote Link to comment Share on other sites More sharing options...
jmhlsy Posted September 1, 2013 Author Share Posted September 1, 2013 No response from zoeller yet. I think I will just go with a "Y" I can get than at the box store. Are there any performance differences? Also, how far is the mig tip suppose to stick down in the fitting? Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted September 1, 2013 Share Posted September 1, 2013 It needs to be the Ward Y. Quote Link to comment Share on other sites More sharing options...
kyotie11 Posted February 26, 2014 Share Posted February 26, 2014 I haven't gotten a response of zoeller either does anyone have any info on this? Quote Link to comment Share on other sites More sharing options...
