Perrin Aybarra Posted April 21, 2013 Share Posted April 21, 2013 As I get nearer to having a forge of my own, I've considered fuels. We have a sizeable woodpile in the backyard, so I'm left to wonder, will I be able to get a hot enough fire to work metal? Or should i really start looking into coal? I've made some rudimentary charcoal before, if that helps. I appreciate any information or tips! Quote Link to comment Share on other sites More sharing options...
knots Posted April 21, 2013 Share Posted April 21, 2013 It's money or time. I make charcoal every day during the winter in my airtight stove, then let it burn to ash. There is a large online community that discusses this subject that would be a good source of information on how to build an air tight retort . But making charcoal takes time that could be spent forging. Coal is a better choice for fuel and it is not excessively expensive. By all means, if you want to make your own charcoal you can and should. However if it is the iron work that is your main interest coal is the way to go. Making charcoal is a time consuming task. When forging with charcoal, it is consumed faster than coal. Use coal if possible. Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 21, 2013 Share Posted April 21, 2013 In and around Louisville, KY coal should be easy to obtain. You can use wood to fuel a forge. You need 2x4x4 inch size chunks for better results. The fire needs to be deeper as you are making charcoal as you go. Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted April 21, 2013 Share Posted April 21, 2013 I have been using strictly coal for the last 4 years. It works great. I still have about 150lbs of coal from my current coal purchase. I have however made my own charcoal retort and now make my own charcoal. It is a little time consuming and as with most everything else there are pros and cons. I almost strictly use charcoal now. If someone comes over to the smithy and wants a coal fire, I oblige them. Pro: I really enjoy the fact that I can make my own. Con: It does take prep time that could be used at the forge. Pro: I also use it on my BBQ grill. Con: You will use a lot more charcoal than you will coal. A lot more. Pro: IT IS FREE! Con: You need to learn to manage your fire differently. Pro: It has a more accepted odor than coal. I like the smell of coal but some don't while at demos. Con: IT IS FREE! Oh wait, thats a pro. There are a lot of people that have a hard time getting or affording coal and charcoal is the better way to go. I set up my retort as I find time so it doesn't conflict with forge time. When I am ready to light it off, I do so and then go forge. I can do everything with charcoal that I can with coal. It all boils down to a personal issue. Find what works best for you. Just remember, charcoal briquets are not good for forging. Did I mention that by making my own charcoal it's free? And I should never run out. Mark <>< Quote Link to comment Share on other sites More sharing options...
knots Posted April 21, 2013 Share Posted April 21, 2013 In and around Louisville, KY coal should be easy to obtain. You can use wood to fuel a forge. You need 2x4x4 inch size chunks for better results. The fire needs to be deeper as you are making charcoal as you go. I forged with charcoal for a couple of years before moving on to other fuels, but never tried using direct conversion of wood to charcoal in the forge. Seems like it would result in an uncomfortably hot work environment not to mention a lot of smoke . But of course if no other choice were available ---. Quote Link to comment Share on other sites More sharing options...
easilyconfused Posted April 22, 2013 Share Posted April 22, 2013 In the cold North, I used to make tons of charcoal by just pulling it out of the wood stove in the shop when it was embers. Needed to keep the shop warm anyways and lots of scrap wood around the farm. I have also used wood in the forge when the shop wasn't warm enough and didn't feel like getting it warmed up for a small project. Like it was said before: Time vs Money. For me, I needed to heat the shop anyways so it didn't take much more time anyways. Wood heating was also cheaper than gas on the farm. Quote Link to comment Share on other sites More sharing options...
dkunkler Posted April 22, 2013 Share Posted April 22, 2013 Not inexpensive, but good quality blacksmithing coal. Cumberland Elkhorn Coal & Coke 950 Swan Street Louisville, KY 40204 Telephone: (502)589-5300 Quote Link to comment Share on other sites More sharing options...
Old South Creations Posted April 22, 2013 Share Posted April 22, 2013 you can absolutely get a hot enough fire using wood/charcoal. historically, coal is a relatively new fuel for forging. Although I personally prefer coal, I have used both effectively Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 25, 2013 Share Posted April 25, 2013 Well charcoal was the only fuel used for forging during the first 2000 years or so of ironworking---started switching to coal in the high-late middle ages in Europe, (Cathedral, Forge and Waterwheel, Gies & Gies) and of course charcoal use continued in parallel to coal use until this day---Japanese swords are traditionally forged using charcoal. When I use charcoal I like to have a separate fire to make the charcoal, I built a shovel out of rock screen to transfer hot coals from the fire to the forge while NOT bringing over ashes or fines. Also the heat of the conversion fire is kept farther away from me---charcoal throws off more heat onto the smith! It helps to have a forge tweaked for it's use as a deep narrow fire works best for charcoal, (especially for blades!) Charcoal and coal have quite similar BTU content PER POUND; but as charcoal is much less dense you go through a lot more of it for the same heat input. Quote Link to comment Share on other sites More sharing options...
Whitlox Posted May 4, 2013 Share Posted May 4, 2013 We use raw wood for blacksmithing. It's true that it can make a lot of heat while the flames use up the wood gas, but you don't need to stand next to it while its burning high. It actually smokes less than a coal fire, at least when managed carefully (not too much new fuel piled on at once.) My hubby is making forges designed just for wood, allowing the deeper bed of coals and insulated to keep the heat in. You can see his design (Whitlox Wood-Fired Forge) and some possibly useful videos at whitloxhomestead.com. Quote Link to comment Share on other sites More sharing options...
