First try at a bearded axe
This was my first go at both an asymmetrically wrapped and a bearded axe head. I started with way too small of stock as I did not want to wait for my steel shipment to arrive. So, I made a hatchet sized head. I started with a length of 1"x1/2" stock. I have been studying James Austin's work and wanted to give it a try.
Here is the starting stock:
The end upset and rough shaped.
Eye formed.
And wrapped
Forge welded and shaped
Split and bit shaped
Forge welding.
welded and ready to be hardened and tempered.
All finished. Im not too happy with the look of the handle but I'm happy overall for a first try at this style.
Thanks for looking!
-Matt P.
  • Replies 64
  • Views 28.1k
Very cool. I will be happy as all get out if my first axe turns out half that well. Nice pictures, too.
Handles are pretty easy to change, so that's almost a minor problem.
very nice.
mark
It looks like quite a challenging piece of work to me!  I think you did a great job!  All those processes are much more difficult than they appear!
Thank you fellas. The edge thickness was ~ 3/16" but the next one I'll cut it at around 1/4" I think.
Very nice! one of these days ill get my feet wet and try that.
Thank you. I made a second one today, non bearded. More of a corner axe.
Thanks for the follow-along pictures. I'm inspired. Awesome work.
That is good work .
I particularly like the "forge welding smile".
 satisfying work is satisfying.
Thank you.
That means a lot coming from you basher. Your work is fantastic, especially your axe work.
So are there actually 2 forge welds, one at the roll for the eye and one for the blade insert?
What did you use for the blade insert?
Amazing work -thanks for sharing
Yes sir there are two forge welds. I used some 1095 for the bits. Thank you!
Thanks!
Here is Number 3 - Some improvement. This one was forged from 3/4" x 2"  4" A36 with a 1095 bit.
From this:
To this:
Loving them all,  hoping to book a course with Basher this year. Thanks for sharing.
John
That is awesome, wow is all i have to say!!! WOW hope i can do that someday soon!
Great work. Love the 2 forge welds method you used. Turned out beautifully.
  • 3 weeks later...
Thank you All!
Ive been very busy, and went a bit over the top with the axes. Ive got a bunch of progress photo but I'll pot some of the pictures that stand out. I think I'm on #10 or 11 of the heads.
Thank you for looking!
Matt P
That is gnarly man. You've just inspired me to try one this weekend.
