January 10, 201313 yr Hi all Andy here just picked up a 90 pound anvil for 20 bucks in not bad nick. I'm sure it will be fine for most tasks I will be attempting in the next few months. But just wondering what I could expect the limits to be on something this weight ? What's your thoughts?
January 10, 201313 yr Well if it's a solid cube then it can take a heap of pounding. If it's a late 19th century American variation of the London pattern with long thin heel and horn then not much. Personally I try to limit my hammer size to under 3 pounds for my A&H 93# anvil of the latter form and have used a 6# hammer on my 25# cube anvil.
January 10, 201313 yr The general rule of thumb I use is...... small anvil, small work. That's not to say that you're limited, though. While I wouldn't try to sledge away on that battleship-anchor project you've been musing over, a 90lb anvil is perfectly suitable for making gates, latches, hinges, spoons, hooks, hammers, tongs, chisels, knives, forks, trivets, fire dogs, and a whole host of other projects. A lot of the anvils used in America, back in the day, were less than 150lb, and they got used for just about everything you can imagine needing around a homestead. The biggest thing to remember is to mount that light anvil very firmly to as heavy a stand as you can come up with. If all you can do is pressure-treated pine lumber, fine. But if you can make a stout stand out of something iron-ish, or bury the end of your lumber stand a few feet into the ground, you'll make a light anvil perform like it was a much heavier anvil.
January 12, 201313 yr An Australian anvil? We need pics! Everything above still stands, though. You might be limited in thickness of stock (nothing over an inch thick), but that leaves an entire encyclopedia's worth of stuff to make. Just be sure to cinch her down to a heavy stand to maximize her capabilities.
January 12, 201313 yr Author Sorry about the paint the misses got to it one day need to take to it with a wire wheel
January 12, 201313 yr The thing is the ratio of hammer weight to anvil weight to get efficiency. As said above a century or more ago most general smithing anvils were small by modern standards and those were used all day by full time smiths. My 1907 catalogue lists anvils upto 84 pounds. Anything bigger was to special order! My baby portable anvil is about 120 pounds. That one gets used for everything if I am away from base. In the shop heavy stuff gets done on the bubba Rhino or the 280 pound Brooks. A good idea for a stand is just cast a block of concrete. Then get the anvil anchored to that. I know some people don't liek concrete bases but I have never understood why. It is very heavy and improves the behaviour of the anvil. If you do that put a couple of pieces of plastic pipe horizontally through the block then twist them out before the concrete has gone rock solid. That way you will have holes for porter bars. I used to have a base made like that for my Papa Rhino and it was great.
January 12, 201313 yr My anvil's only 110, I added a bit of beef with the stand 2" thick top plate, heavy gusseted legs, big foot pads that can be staked to the dirt or anchored to concrete. It makes the anvil feel like it weighs twice as much. Goody gutsy stand there. Well done.
January 12, 201313 yr Make sure you have a heavy solidly built stand, bolt or stake the stand down very firmly. (If staked in a semi perminant shop situation, use at least 4-foot 1/2-inch rebar stakes.) The fasten the anvil to the stand securely. Don't weld it to the stand but use some sort of bolted or wedged bracket. Then forge on it! Brian Brazeal (a well noted member and an excellent smithing teacher,) uses around an 80-90 pound Henry Wright anvil, and frequently forges 1.25-inch material with a 5-pound hand hammer and occasionally a 12-pound sledge with a striker. The key is to make sure your anvil can't go anywhere. That little 80 pounder of Brian's was more solid than my 290 pound shop anvil on a 50 pound stand, before I staked/bolted the anvil down. You have a very clean anvil nice little anvil, now do it justice with a good sturdy stand, and some good bolts.
January 12, 201313 yr Nice looking anvil, clean face, good edges, no chips I could see and a good weight if mounted solidly. Aw, leave the paint it doesn't hurt a thing and if the color of your anvil is what someone uses to judge your work their opinion isn't worth noting. Besides it might give you a couple bargaining chips with the wife someday. <wink> Frosty The Lucky.
January 13, 201313 yr G'day andys! Andrew here in sydney. The only other thing I could add to all the quality advice above is a tale of another Bradford Kendall anvil. Where I started my apprenticeship we had a 3 cwt Peter Wright and a 2 cwt BK. No one used the BK 'cos it was so noisy, just sitting on it's stump made of 4"x4" blocks on end. One day, when it was quiet, I re-did the straps to hold the blocks tight, then got the toolmaker to turn up some flash tapered spacers to coach screw anvil through the holes in the feet. Unexpectedly, the ringing went away! Check out; http://bradken.com/ourcompany/history and: http://en.wikipedia.org/wiki/Bradken I don't know when exactly they made anvils, at least either side of the nineteen seventies. cheers, AndrewOC
January 13, 201313 yr Author Awesome thanks for the info will get onto a stand tomorrow I think. Will have a look for some decent steel for a base too. If not I might try the Concret idea.
