Blackwaterblacksmith Posted December 22, 2012 Share Posted December 22, 2012 I saw a bending jig on ebay that I would like to try building myself instead of paying almost 400.00 dollars for it. The biggest die that comes with the jig is 6" in diameter and the base plate is 9" in diameter. I can obtain all of the round stock for the jig except for the 4",5",6" and the 9" base plate. Maybe someone on here can help me out??? The dies and the base plate should be cut from 3/4" thick. I'm tryin to do this as cheap as possible but I don't have a scrap yard anywhere around me that sells metal back to the public and if I buy the steel new from a welding shop or what ever and have them cut it out for me I'm looking at pretty close to $400.00. I guess what I am looking for is someone that has some 3/4" plate that can cut these dies out for me. Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 22, 2012 Share Posted December 22, 2012 Why not use short sections of 4, 5, 6, 8 inch pipe or round bar? Quote Link to comment Share on other sites More sharing options...
Blackwaterblacksmith Posted December 22, 2012 Author Share Posted December 22, 2012 Hope that works. Quote Link to comment Share on other sites More sharing options...
clinton Posted December 22, 2012 Share Posted December 22, 2012 What would work best would be round stock in the diameters needed. And a lathe that has the capacity for those sizes. Chuck them up and drill a hole, with a 3 jaw chuck it will center itself, no lay-out required. That guy sells alot of those benders, I wonder how useful they really are. I see it collecting lots of dust if it were in my shop Quote Link to comment Share on other sites More sharing options...
knots Posted December 22, 2012 Share Posted December 22, 2012 Seems like finding a piece of round 3/4"plate the right diameter on any scrap pile is a non starter. However a nice square piece of plate near the correct size might be findable and workable. The corners of a square plate could be trimmed to form an octagon for a close approximation to round. If your welding table is 3/4" plate why not build it into one corner of the top ? Or if really desperate laminate a couple of pieces of plate together to form the base.. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted December 22, 2012 Share Posted December 22, 2012 There is no need for the base to be round. That's simply what the maker has available, and makes the whole thing look "right". While the bending jig is rather useful for making repeatable curves, there are better designs out there. Personally, while I like the idea, I would rather use a square table that has a series of holes in a grid pattern so that I can use it to make compound bends around multiple radii, like a serpentine finial you see on gates and railings. You can still bend simple curves, but it opens the door to other uses. Using sections of pipe to supply the radii is far easier and cheaper than using solid stock. A lot of the time, you can find piping in 1' sections at the flea markets and re-sale stores. Pots and pans can also be repurposed. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 23, 2012 Share Posted December 23, 2012 This is pretty obviously a home made bender and for $400 you should be able to find a Hossfeld (sp) or similar commercially made bender. Keep an eye on Craigslist and eBay you could get lucky. Another place to look for is old schools/shop classes closing, fab shops, especially ones specializing in decorative work, etc. having sales or auctions. Don't forget to tell EVERYBODY you know or run across from the checker at the local 7-11, your Pastor and Parishoners, your kids' teachers and class mates, etc. You get the idea. For one offs I've used plywood for the ID die and simply clamped a roller to a bar handle in the right place. Sure it won't last for more than one or two bends but if you can take the smoke and flames you can soak it in oil and it'll last longer. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
possumfat Posted December 23, 2012 Share Posted December 23, 2012 you should try a local steel vendor, I probably am spoiled to have about 5 within a half hours drive. they have large band saws that will slice off pieces of steel that are large diamater like that. if they have a decent saw they could cut pretty square. then there is no need for the pieces to be faced on the lathe. then maybee a drill press for the center hole? Quote Link to comment Share on other sites More sharing options...
LarryM Posted December 23, 2012 Share Posted December 23, 2012 This bender is an easy build with a drill press, and welder. I built one of these a few years ago. It works very well. Besides the pipe dies, I use dies that I made by bending strap iron to the right diameter. If you need a heavy duty unit, it can be scale up. If you are interested I'll post pictures of mine. Old Metal Bender.pdf Quote Link to comment Share on other sites More sharing options...
baker101z Posted December 23, 2012 Share Posted December 23, 2012 Some good info in here. Larry, I would be interested in some pics of your bender for sure. Quote Link to comment Share on other sites More sharing options...
clinton Posted December 23, 2012 Share Posted December 23, 2012 That is a pretty slick copy of a small Hossfield bender Quote Link to comment Share on other sites More sharing options...
LarryM Posted December 23, 2012 Share Posted December 23, 2012 This bender is an easy build with a drill press, and welder. I built one of these a few years ago. It works very well. Besides the pipe dies, I use dies that I made by bending strap iron to the right diameter. If you need a heavy duty unit, it can be scale up. If you are interested I'll post pictures of mine. Here are some picture of my bender attached to the side of my hydrualic press. The last three are of dies that I've made. As you can see they don't have to be anything fancy most of mine are just throw togethers. The football shaped ones can be used as feed along dies to make rings. Quote Link to comment Share on other sites More sharing options...
baker101z Posted December 26, 2012 Share Posted December 26, 2012 Good stuff. Thanks, Larry. I think I know what my next project is. Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted December 26, 2012 Share Posted December 26, 2012 I keep coming back to this simple fact; things are always easier if you don`t insist on working in a vacuum. If you find and join the local club or guild in your area you`ll surely meet everyone you need to know as far as getting on top of both techniques and materials. Well worth the price of admission (the annual dues) and far,far cheaper when many hands are involved in both the making process and the buying of the materials. Quote Link to comment Share on other sites More sharing options...
fciron Posted December 27, 2012 Share Posted December 27, 2012 That is a pretty slick copy of a small Hossfield bender Actually, the OP's bender is a pretty slick copy of a DiAcro bender. LarryM's bender is a pretty slick copy of a Hossfeld. Both makes have instructional booklets available online that can give all sorts of ideas for homemade dies and fixtures. Quote Link to comment Share on other sites More sharing options...
LarryM Posted December 27, 2012 Share Posted December 27, 2012 Fciron, You are right both Hossfeld, and DiArco have websites. They have downloads of there catologs which you can use to learn to use these benders. Larry Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 27, 2012 Share Posted December 27, 2012 Note if you can find a place that does structural steel work you may find a source of heavy steel disks that are cut out and *scrapped*. Also in VA I'd check around ship building and repair yards if you ever travel near the coast. Quote Link to comment Share on other sites More sharing options...
