November 8, 201213 yr I am trying to find a foundry that will pour cast iron swage blocks. Preferably this foundry has some molds already that we can pick from. I am with the Blacksmiths Association of Missouri (BAM) and would like to source and inform our members as to the cost so that we can determine quantity and put an order in. I think the size of the blocks would be roughly 10" tall x 18" wide x 24" long and weigh 100 pounds plus. Thanks for any feedback. JH P.S. - Is this the right way to approach this or am I missing something.
November 8, 201213 yr 100 lbs sound quite a bit light for something that size. I would guess that would be closer to 500 lbs depending on holes, I figure 60% air space. That size steel block is 1200 lbs if solid.
November 8, 201213 yr Salt Fork Crafters has a place that casts swage blocks for them and others, i have one it's about 70 lbs or so. i think you can contact them through this site, or Glenn will know how to contact them.
November 9, 201213 yr On this main forum page, a man from Elizabethtown, PA, "wdandmlteach" meaning Wood and Metal Teacher, posted under "Tools" 'Swage Block Ponderings.' He knows how to make a pattern/matchboard, I doubt whether you can find a modern day foundry with already made-up patterns. Most moderate sized swage blocks are three to four inches thick. Many of them were square; a few, rectangular. Some had holes through them; some did not. The old ones were usually gray cast iron, but nowadays they can be of ductile iron. Saltfork Craftsmen of Oklahoma had already located a foundry and they are selling mandrels and swage blocks. Steve Fontanini has a foundry in one of the Western states to cast the anvils that he sells. He might have some info. I suggest that you go to www.swageblocks.com and look at the gallery of old and new swage blocks.
November 9, 201213 yr Blacksmith suppliers like Kayne & Son, Centaur, and Pieh would have direct contacts in the industry. Whether vendors would be willing to share that information may be another matter. They can and usually do purposely hide the makers mark in their photos and leave it out of their descriptions.Someone is casting the Rhino, Fontinini, Nimba, and various farrier anvils in the US. You might ask them.Laurel Machine and Foundry (Laurel, Mississippi) was the last large US maker that I knew of casting swage blocks and cones. For them it was a tiny, tiny sideline.Green & Mengel (US) also made some blocks and cones in various sizes. John Newman did cast 3 very different block patterns in Canada a while back, and some items from both makers still seem to be available from the above vendors. I have used products from both and they were well worth the price. Edited to make clear: I am not advising you to rip off an existing design or designer, just some off the cuff leads to help you find a reputable foundry or partner to work with.
November 9, 201213 yr http://www.incandescent-iron.com/index.html is making the Rhino anvils and they have a small swage block too I believe. I don't know who their foundery is.
November 9, 201213 yr Most of the patterns at foundries belong to their customers not the foundry. The foundry cannot use the pattern to make a casting for anyone but the owner of the pattern. They would be opening themselves up for a lawsuit and losing a lot of other work.
November 9, 201213 yr I've thought of tracking down the Foundry in Mexico that's casting the anvil fakes and swage blocks we see out this way.
November 9, 201213 yr If you can't find a foundry to cast for you you could keep an eye out for an iron pour. We have one every June and with a little coaxing and a lot of cast iron hammering for stock they'd be happy to pour a swage block. Any idea how many steam radiators you have to sledge hammer to bits for 100-200lb pour? Oh my aching arms. Finding a pattern maker shouldn't be too tough, the biggest difference between metals is the shrinkage allowance. Once you have the pattern most any foundry should pour for a price. Don't forget quantity makes for cheaper unit prices. A large foundry would maybe include small pours like a swage block to use the last iron in the melt, like getting the cement truck to pour the flagstones when they clean the drum. It's always better to make a few bucks than toss or have to reprocess leftovers. Frosty The Lucky. Frosty The Lucky.
November 10, 201213 yr We have a very small local foundry in my town. send me details. i will approach them for you. worst they will say is no. send me details via private message. So i dont miss them...lol
November 11, 201213 yr Either he wants the physical size which would weigh in the 500 lb neighborhood or he wants a 100 lb small one, which there a new ones to choose from. He has not been back to specify so.....
November 12, 201213 yr Author Thanks all for the help so far, what I need to do is get back to my association president and try to determine the actual design/size. Also, you all have given me a lot of leads that I need to investigate and quit trying to recreate the wheel. Does anybody roughly know what the range of costs might be on 100 lb block vrs a larger one?Thanks again, you all have saved me a lot of time.regards,jh
November 12, 201213 yr Just a suggestion if you are designing your own swage block: I have a small one, 50# or so, that I bought on ebay about a dozen years ago. For the most part it serves my purposes. However, one thing I have wanted that it doesn't have are triangular grooves. By this I mean true 60 degree equilateral triangles. It does have grooves with a 90 degree bottom but that doesn't give a true equilateral result. I've considered filing some in with a triangular file but that seems like a LOT of work and I haven't missed that shape enough to invest that much time and work. Sooner or later I probably will. Also, if you are making them large enough I'd suggest graduated bowl/ladle depressions. There have been times that I have wanted an intermediate radius between the small and large ones that I have. Finally, consider the effort needed to shift them around. 100 pounds is probably the upper end, IMO, for one man to shift, particularly us older fellers. Good luck, and let us know if you are going to have some excess ones for sale. I'm sure that there would be a demand. Depressingly, George M.
November 12, 201213 yr I have two blocks in the 125 range and they are about the limit I want to move around. Flipping them in the stands to get the right side up is a pain by yourself. I also have a smaller 85 lb block that is square and I use it for portable I think it was cast in Mississippi or someplace about 10 years ago. A couple years ago we did a buy (BAM did) from salt fork for the ones they did around 100 lbs and I think everyone was happy with the result. It seems like we are reinventing the wheel here or maybe I am not understanding what the desired size is.
November 13, 201213 yr George; go over to VO-Tech and see if they would make you a set of 60 deg grooves in a linear block you could add a stem to and use in your hardy hole---perhaps two blocks a small set and a large set.
November 13, 201213 yr Spokane Industries http://www.spokaneindustries.com has great capabilities and can pour about anything you want to pay for. I think that's who casts the Rhino Anvils for Steve. I have one of his anvils and like it.
November 13, 201213 yr Iron Quake, that makes total sense to me. Incandescent Iron Works is in Spokane. I am seriously thinking about getting their swage block. Anyone have any experience with it?
