March 30, 201214 yr So I had a nightmare that I was forging a cut off Hardy and when upsetting it broke off the heel of my 125 lb HB. Anyone else had similar experiences? Yes I would consider that a nightmare and it would rank in my top five ever if I had a list.
March 30, 201214 yr Back when I started the craft show curcuit, I used to have nightmares about forgetting matches, paper, coal, or leaving all my small tools behind. LOL My confidence level must have increased because it's been a while now. I don't recall any about breaking anything, though!
March 30, 201214 yr Make a bolster plate that matches your hardy. Then you can confidently tell your nightmare to take a long walk off a short pier. Bolster plate in shop, you will never use your hardy for a task that will risk your anvil breaking! Phil
March 30, 201214 yr Author How do you make a bolster plate? Cut a hole the size of you Hardy in half inch or better plate steel then burn a hole in a stump the same size and fasten the steel over it?
March 30, 201214 yr That would do the trick well. Make yourself a diamond point cold chisel, and a narrow cold chisel that is ground more like a wood chisel, with the cutting edge to the side instead of in the middle, and check out the end of this video.http://www.youtube.com/watch?v=pxTdbC5MLRQ&feature=plcp&context=C4e8740eVDvjVQa1PpcFOo_aFHC1nmldkoRfKGdgSKydQQxVLNtf8%3D I used a piece of 1x3 mild steel, it took me about an hour to make the hole, but that was the second time I cut a hole of that nature by hand. I started with four 1/2 inch holes in a careful pattern. Phil
March 30, 201214 yr I have an old mousehole anvil with a 5/8" harder hole. So I made a Brian brazeal striking anvil with a 1" harder hole it is worth the investment and you will not break off the heal,
March 30, 201214 yr That is a nightmare! Hope it's not of the reoccuring type. I have one a few times a year where I'm back in the classroom and I've been retired from teaching six years . Maybe a form of PTSD ?
March 30, 201214 yr We used to take Caterpillar dozer valve lifters and forge them into hardy tools doubleteaming them with sledges in a 400 pound anvil---some thing that make me break out in a sweat just thinking of it nowadays---so many better ways to accomplish that with less danger to the anvil!
March 31, 201214 yr unfortunate i would say that dream is not about work at all ! maybe its your brains way of sorting out stuff in imagery that mean something to you ? why are you unfortunate anyway ? am intrigued... :)
March 31, 201214 yr I use my swage block if I need to forge a hardy shank, not going to break it with human muscle and a hammer. It's not uncommon to have dreams about a new job, skill, etc. You could ask Deb about me operating graders in my sleep. Frosty The Lucky.
March 31, 201214 yr I misread your post- I thought you actually broke your anvil. I've upset plenty of tools in my hardy hole-not worried about busting the anvil-very unlikely in my opinion.
April 2, 201214 yr Having an accident in a car is very unlikely too; but I still wear a seatbelt! I like to evaluate the risk vs return on things and so choose to only do light shaping of a hardy stem using the hardy hole and heavy shaping in something I wouldn't be upset if it broke. When I'm sizing the stems for my 1.5" hardies I do most of the work in my big screwpress. If I get them a tight fit when red hot they are just about perfect in my judgement when they are cold.
