jcornell Posted September 14, 2011 Share Posted September 14, 2011 A dear friend of mine from college is a Franciscan priest. He's looking to commission a stand for a processional cross. As I understand these things, the cross is basically a long dowel with a cross on the end, so the stand has to be something like a flag pole stand - a stable base and a tube (of some sort) to put the dowel end of the cross at the end of the procession. Any notion where I could look at examples? Any helpful suggestions? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 14, 2011 Share Posted September 14, 2011 Where will it be located? Nice scrolls going from the feet to the tube are a pretty design *if* people will not be walking through a confined space with the base a tripping hazard. If it would be a tripping hazard a flat disk, perhaps with plasma cut designs would be better. Or put the scrolling as the legs and have just the tube rising above it. An adjustable tube might be nice as many churches have a number of Processional Crosses, Candles, Flags, Banners, etc and the better the fit the better it looks. Perhaps a series of nesting tubes with slight tabs at the top to make them easily changed out? Quote Link to comment Share on other sites More sharing options...
macbruce Posted September 14, 2011 Share Posted September 14, 2011 How big of material can you forge? Quote Link to comment Share on other sites More sharing options...
jcornell Posted September 14, 2011 Author Share Posted September 14, 2011 How big of material can you forge? Realistically, probably up to 1", but I normally play around with 1/2" without too much fuss. My gasser has a door in the back, so I can do a fairly long piece. Quote Link to comment Share on other sites More sharing options...
John B Posted September 14, 2011 Share Posted September 14, 2011 I would suggest a visit to some cathedrals or large churches to get some ideas. Where and do they normally store this cross? I have made some processional banners/crosses holders, but they were mounted to a wall, socket at the base, to locate the staff base, and a standoff bar (semi circular or triangular) with a location U for the staff body to fit in, with a latch acroos the front to hold the staff in place, the location area being lined with felt to stop abrading the staff, The whole item then tilts forward slightly when in situ, allowing any banners to hang free and vertical without rubbing or wearing on them. They can be mounted low down or higher up depending on the item being supported. I lke to keep them simple with twists or some other decoration, rosettes, crosses etc Quote Link to comment Share on other sites More sharing options...
SmoothBore Posted September 14, 2011 Share Posted September 14, 2011 Google up "Cross of St. Francis" or "Tao Cross" for a start. Also, ... I think Vines with Grape clusters, are a Franciscan thing. Particularly, a cluster of 5 grapes, is symbolic of the 5 wounds of Christ.For what it's worth ..... Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 14, 2011 Share Posted September 14, 2011 Start with an appropriate piece of pipe, then attach some scrollwork to form 3 legs with feet. I would "blind weld" the scroll work to the pipe and grind it flush so the inside of the pipe is smooth. Think about protecting the wooden pole with how the pipe lip is finished, and make sure the bottom is partially blocked, but not fully sealed since people (kids) put stuff in things they ought not to. A washer or single bar so the base can be lifted with the cross in it, and the cross won't fall out should do the trick. Having 3 feet means it can sit fairly tight to a wall or corner (inside or outside) as well as being self leveling. Phil Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 14, 2011 Share Posted September 14, 2011 What about skipping the pipe and make the holder a series of vines twining up with the gap in the middle for the shaft (probably make it with a piece of pipe as the mandrel...) Quote Link to comment Share on other sites More sharing options...
rthibeau Posted September 14, 2011 Share Posted September 14, 2011 if he's looking for just the stand, then you need to see the bottom of the cross to know how to make the stand to fit. In our church, the cross has a pin protruding from the bottom that slides into a hole in the stand. Once you know what the bottom of the cross is, you can design the stand accordingly. Quote Link to comment Share on other sites More sharing options...
HWHII Posted September 15, 2011 Share Posted September 15, 2011 I have a few here at our chapel and I can provide a pictures for you. They are not forge but still very nice. Just let me know. Quote Link to comment Share on other sites More sharing options...
