oakwoodforge Posted October 19, 2006 Share Posted October 19, 2006 I've tried a bunch of things to remove fingerprints and oils from blades before I etch them. Things like simple green, spray brake cleaner, rubbing ancohol, paint thinner, engine degreaser... But I found something that works really nice and easy,3M Quote Link to comment Share on other sites More sharing options...
V Posted October 26, 2006 Share Posted October 26, 2006 Useful tip, I´ll try it. If it takes out wax can take out any grease, for sure Quote Link to comment Share on other sites More sharing options...
Christopher M Posted October 26, 2006 Share Posted October 26, 2006 I just use plain old dish soap the cheap kind you get for a buck and a sponge.I works great for me of course my blades usually go right to etch after sanding. Quote Link to comment Share on other sites More sharing options...
kbaknife Posted August 22, 2007 Share Posted August 22, 2007 I wipe off with Acetone. Take into the house and wash with dish soap and hot water to remove any petroleum distillates from the acetone, and then just prior to etching, wipe off with denatured alcohol. Quote Link to comment Share on other sites More sharing options...
jim frank Posted September 5, 2007 Share Posted September 5, 2007 I'll have to try the wax remover. Sounds good. Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted September 18, 2007 Share Posted September 18, 2007 With the wax and grease remover, make sure ya wipe off with a clean towel before dipping. That stuff does leave a residue. Quote Link to comment Share on other sites More sharing options...
Conan_568 Posted November 2, 2007 Share Posted November 2, 2007 I just use plain old dish soap the cheap kind you get for a buck and a sponge.I works great for me of course my blades usually go right to etch after sanding. I use the same thing followed by a wipe down with pure alcohol. I etch in battery acid, it gives a slow etch that I like. Quote Link to comment Share on other sites More sharing options...
ksb Posted November 6, 2007 Share Posted November 6, 2007 I spray with brake cleaner, rinse with water then wipe off with acetone - seems to work for me. Ken Quote Link to comment Share on other sites More sharing options...
Lamey Knives Posted November 8, 2007 Share Posted November 8, 2007 after trying a multitude of pruducts, acetone gives me the best results.... usually wipe down 2-3 times before etch. Quote Link to comment Share on other sites More sharing options...
EdCaffreyMS Posted November 14, 2007 Share Posted November 14, 2007 I agree with the acetone. I usually follow that up with a quick shot/cleaning with windex, then etch. Quote Link to comment Share on other sites More sharing options...
Hollon Posted February 9, 2008 Share Posted February 9, 2008 Just out of curiosity kbaknife, why would there be petroleum distillates in your acetone? Quote Link to comment Share on other sites More sharing options...
Badger1875 Posted February 28, 2008 Share Posted February 28, 2008 Sandblast it! This is the way I go and I never had any problems with it. If you use acetone or any other solvent, you still might keep something on the surface, except you wash it. And even then the time will come and there is so much oil, grease or so in the acetone (or so), that it will cause problems again. Badger Quote Link to comment Share on other sites More sharing options...
Chuck Richards Posted March 9, 2008 Share Posted March 9, 2008 Do the acetone and windex. Also once in the etch take it out after about 30 seconds and make sure it is etching evenly. I then rub lightly with 1500-2000 grit wet dry. If there was anything left on the blade it will be removed and not leave any resist on the blade. Quote Link to comment Share on other sites More sharing options...
nonjic Posted March 9, 2008 Share Posted March 9, 2008 ive been useing washing up detergent on a new (grease free!) pot cleaning sponge, rinse very thoroughly then dry it untill its squeaky dry with tissue. Im sure the other ways are better, but sometimes you have to work with what ya got ! Quote Link to comment Share on other sites More sharing options...
atakach Posted April 4, 2008 Share Posted April 4, 2008 i like to use carb cleaner to remove all buffing coumpounds and grease, then i put in boiling TSP(tri sodium phosphate) dont really need to as the card cleaner works fin enough IMO but tsp really cleans the oils off good, over kill on the cleaning can never hurt IMO Quote Link to comment Share on other sites More sharing options...
wolfy9005 Posted June 29, 2008 Share Posted June 29, 2008 Battery acid ie. sulfuric acid. careful that it's cold, they use boiling h2so4 to test how resistant metals are to acid by dropping them into it and counting how long it lasts. I think they usually last a few seconds :P Quote Link to comment Share on other sites More sharing options...
