Norseman C.B. Posted July 25, 2010 Share Posted July 25, 2010 Anybody out there got A good recipe that dont crumble after use ? :unsure: Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted July 28, 2010 Share Posted July 28, 2010 I have never use this yet but this web site puts out good info. hope it helps http://www.backyardm...fractories.html Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 28, 2010 Share Posted July 28, 2010 Just remember that the reaction that cures portland is driven backwards at about 500F Phil Quote Link to comment Share on other sites More sharing options...
Kenny O Posted July 28, 2010 Share Posted July 28, 2010 Just remember that the reaction that cures portland is driven backwards at about 500F Phil I don't understand what this means? Thanks Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 28, 2010 Share Posted July 28, 2010 I don't understand what this means? Thanks Portland cures by absorbing water into the molecule. At about 500F and hotter, the water is driven off, making the portland no longer bind anything together. This means that if portland is used to bind your castable at high temperatures the castable disintegrates. An alternative that is cheap, but much less easy to make, is to use high fire clay and grog. Grog is simply smashed vitrified clay. Vitrification is heating till the clay recrystallizes. This will require a ceramics kiln of some sort as the time at temperature is in hours. Kaolin and porcelain are good choices for this process. Using a lesser insulation with the understanding that it has a limited life is reasonable too. Phil Quote Link to comment Share on other sites More sharing options...
Kenny O Posted July 28, 2010 Share Posted July 28, 2010 Thank you for the schooling. Does this mean that some of the Portland would become airborne, and would the PPM be significant? I dabble in ceramics, take classes from community college. I will have to run this by the instructor see if he can help come up with a good castable refractory . Very informative thank you Kenny O Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 28, 2010 Share Posted July 28, 2010 I don't know about airborn, bit it will spall and slump. Phil Quote Link to comment Share on other sites More sharing options...
welder19 Posted July 28, 2010 Share Posted July 28, 2010 Definately leave out the portland. Use a high temp clay, I prefer Kaolin, which runs $10-$15 for 50lb, use silica sand or grog, approx 20lbs grog/sand to 50lb of clay, to reduce shrinkage and add strength and if you want it to be insilated add in some foam beads, bean bag chair filling works good, add as much foam as your mix will allow and still hold together, add water very little at a time and mix well. Then do 1/4"-1/2" hot face, [clay mix with no foam in it]. Let it dry slow and then fire it slowly, if you fire it too fast it will crumble. It will handle 3000F with no problem. I use this mix for my forges and casting furnaces. welder19 Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 31, 2010 Share Posted July 31, 2010 This site was posted as part of a reply in the home made hand crank blower thread and down the page is the Gingery book on making a melting furnace. As I recall there was a refractory recipe. http://www.amazon.co...n/dp/0917914600 Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 31, 2010 Share Posted July 31, 2010 Frosty's link is broken, can he blame it on a Great White...Birch? Here it is. http://www.amazon.com/Design-Build-Centrifugal---1987-publication/dp/0917914600/ref=sr_1_1?s=books&ie=UTF8&qid=1280535412&sr=1-1 Phil Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 31, 2010 Share Posted July 31, 2010 YES! All my mistakes, misdeads or other failings are to be blamed on being attacked by the Great White . . . Birch! Thanks for the patch Phil. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
LarryM Posted July 31, 2010 Share Posted July 31, 2010 Like Phil, and Frosty, I have several of David Gingery's Books. The centrifugal fan book is very good. I have built several fans using this book. Home brew furnace refractory recipes can be found in the charcoal foundry book. Larry Quote Link to comment Share on other sites More sharing options...
Norseman C.B. Posted August 2, 2010 Author Share Posted August 2, 2010 Thank you very much for the input guys,the recipe I was looking at came from the backyard casting site, the site has a wealth of info but, the recipe calls for portland cement, thus the crumble effect.would a crushed old toilet work for grog ? I have fire clay, sand, and, pearlite for insulation,the hot layer sounds like a good idea. Would 72 hours cure time be adequate before a multi stage slow firing ? O.H. by the way 2 dog, are you one of the 2 dogs over the hill from K falls? If so Ive seen some of your work ..Good of course. HAMMER HAPPY DUDES Clifford B) Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 2, 2010 Share Posted August 2, 2010 Thank you very much for the input guys,the recipe I was looking at came from the backyard casting site, the site has a wealth of info but, the recipe calls for portland cement, thus the crumble effect.would a crushed old toilet work for grog ? I have fire clay, sand, and, pearlite for insulation,the hot layer sounds like a good idea. Would 72 hours cure time be adequate before a multi stage slow firing ? O.H. by the way 2 dog, are you one of the 2 dogs over the hill from K falls? If so Ive seen some of your work ..Good of course. HAMMER HAPPY DUDES Clifford Any high fire clay that is being disposed of will work. Toilet is prime due to the quantity from one go, but you have to smash it down quite far, below 1/4 inch screen for good results, sand-like is better. In truth old china is somewhat easier, but hard to get stuff you feel comfortable destroying because it is either expensive or you are breaking plates. Clean the toilet before you start, and let it dry on end overnight. Trust me. Phil Quote Link to comment Share on other sites More sharing options...
Kenny O Posted August 2, 2010 Share Posted August 2, 2010 O.H. by the way 2 dog, are you one of the 2 dogs over the hill from K falls? HAMMER HAPPY DUDES Clifford I recently moved to Cnt Pnt, there may be others..... Quote Link to comment Share on other sites More sharing options...
Norseman C.B. Posted August 3, 2010 Author Share Posted August 3, 2010 Any high fire clay that is being disposed of will work. Toilet is prime due to the quantity from one go, but you have to smash it down quite far, below 1/4 inch screen for good results, sand-like is better. In truth old china is somewhat easier, but hard to get stuff you feel comfortable destroying because it is either expensive or you are breaking plates. Clean the toilet before you start, and let it dry on end overnight. Trust me. Phil Thanks Phil; I can imagine the pitfalls of not cleaning the victim... :wacko: Quote Link to comment Share on other sites More sharing options...
Norseman C.B. Posted August 3, 2010 Author Share Posted August 3, 2010 I recently moved to Cnt Pnt, there may be others..... Gotcha 2 dogs, could be another outfit.. take care Norseman Quote Link to comment Share on other sites More sharing options...
Ulric Posted August 11, 2010 Share Posted August 11, 2010 Trying the lively adobe mix, with using a higher clay/ash slip as a surface coat... though now im kicking round the idea of busting up a couple old toilet tanks and letting the pieces tumble around in my cement mixer for awhile and adding that to the slip. Quote Link to comment Share on other sites More sharing options...
Norseman C.B. Posted August 11, 2010 Author Share Posted August 11, 2010 Trying the lively adobe mix, with using a higher clay/ash slip as a surface coat... though now im kicking round the idea of busting up a couple old toilet tanks and letting the pieces tumble around in my cement mixer for awhile and adding that to the slip. Ulric; would you explain this lively adobe mix and clay/ash slip in more detail please ? (my skull can be thick sometimes)............... B) Quote Link to comment Share on other sites More sharing options...
Ulric Posted August 11, 2010 Share Posted August 11, 2010 Ulric; would you explain this lively adobe mix and clay/ash slip in more detail please ? (my skull can be thick sometimes)............... These are the only two links I have, found/stumbled on other sites and Tim's video provides some info in regards to it to. http://www.knifenetwork.com/workshop/tut_large_adobe_lively.shtml Now, gather a few gallons of fine sand and a couple gallons of wood ashes along with an arm load of dead grass, dried moss or straw. Take one one of the buckets of cactus tea and add in one gallon of clay slurry, one gallon of sand and one gallon of wood ash. Mix thoroughly with a stick or something. Don't use your bare hands. The ashes in the mix along with the abrasive action of the sand will literally eat the skin off your fingertips. Use gloves when needed. Don't add any dead grass yet. in trying this, after the mass adobe has been placed and dried that idea is try a ..thinner application of clay/ash/sand ratio mix over that. None of these are in short supply around here much just needing a shovel and bucket to collect. Trying to get the 'rocks' or, what I was raised to identify as 'iron ore' out of the clay can be a bit annoying, but I've got plenty of time on my hands. :-) Im using clay dug from a retention pond in the 'pasture', fine sand left from some concrete projects, ash from a recent pile of logs/brush we burnt off and dried/shredded bamboo leaves for the insulation layer. slip/slurry coat clay a clay/ash... If/when I get my cement mixer back, I want to bust up a toilet tank toss it with some large pipe fittings and spin it for awhile and see porcelain fines I can get out of it. If I can get a decent amount I may through that into the slip/slurry mix for a surface coat. Quote Link to comment Share on other sites More sharing options...
Norseman C.B. Posted August 13, 2010 Author Share Posted August 13, 2010 Thanks Ulric this looks interesting and I have most of the elements at hand for this B) Quote Link to comment Share on other sites More sharing options...
Ulric Posted August 13, 2010 Share Posted August 13, 2010 Thanks Ulric this looks interesting and I have most of the elements at hand for this If i can find it again, there was a site (or 3) that told you how to check the soil/clay content for suitability. Testing Soil If you are not sure about the soil you want to use, there is a way to test it out. Fill a glass jar about 2/3 full of soil. Add water until the jar is full, and shake it for about 2 minutes. Set the jar down and let it sit overnight. When you check the jar, the soil should be broken up into two distinct bands of dirt. The sand should be settled on the bottom with the clay on the top. There should be more sand than clay. A ratio of about 70 percent sand to 30 percent clay is ideal for making adobe brick. I didn't like the...idea of waiting 3-5+ days for it to dry out on it's own, so... I set the thing over a fire to dry it out. There are some nice cracks to fill in, and some of the thin spots flaked (1/16-1/8 thick areas) but the rest is HARD/Solid. Once it's cooled down enough to handle, I'll make a thicker batch (first was a tad, wet) finish the fill in... dry it then try the slurry coat. Quote Link to comment Share on other sites More sharing options...
2703adam Posted August 14, 2010 Share Posted August 14, 2010 Has any one tried to crush sheet rock and use that in a recipe? I put my torch to a piece of it and it seemed like it was somewhat insulating. Just an idea... Quote Link to comment Share on other sites More sharing options...
kcrucible Posted August 15, 2010 Share Posted August 15, 2010 gympsum (ie sheet rock) is somewhat fire resistant, but breaks down at high temps. there's a reason that you don't see sheetrock left after a home fire. http://www.usg.com/sheetrock-gypsum-panels.html#tab-faqs Q: What is the maximum temperature that SHEETROCK® Brand Gypsum Panels can withstand? A: SHEETROCK® Brand Gypsum Panels can withstand temperatures up to 125°. Quote Link to comment Share on other sites More sharing options...
Kemp_l Posted February 14, 2016 Share Posted February 14, 2016 On 7/28/2010 at 4:46 PM, welder19 said: Definately leave out the portland. Use a high temp clay, I prefer Kaolin, which runs $10-$15 for 50lb, use silica sand or grog, approx 20lbs grog/sand to 50lb of clay, to reduce shrinkage and add strength and if you want it to be insilated add in some foam beads, bean bag chair filling works good, add as much foam as your mix will allow and still hold together, add water very little at a time and mix well. Then do 1/4"-1/2" hot face, [clay mix with no foam in it]. Let it dry slow and then fire it slowly, if you fire it too fast it will crumble. It will handle 3000F with no problem. I use this mix for my forges and casting furnaces. welder19 sorry about the message in an old thread.But this is exactly what I think I need. <<<>>> Has anyone made this formula in the 5yrs, and how did it work. Where else can I get bead foam? For the hot face do you let the first part dry then press on the half inch hot face and let it air dry? How thick should the first wall be? After it is cured and sure it is, can a person paint the inner face with itc-100. Quote Link to comment Share on other sites More sharing options...
