July 14, 201016 yr Just cut a hole in the wall and stick most of it outside! Hey Grant don't joke now, thats the only way I can get my mill and lathe in my matchbox workshop Think I might write an article on surviving in the small workshop for that Baptists website of yours
July 14, 201016 yr Hey Grant don't joke now, thats the only way I can get my mill and lathe in my matchbox workshop Think I might write an article on surviving in the small workshop for that Baptists website of yours Im gonna think about that picture next time I want to complain about being cramped for space... Man David that looks a wee bit jammed in there...
July 14, 201016 yr I have a question about power hammers..My shop is small, a 12x12 building with a ceiling of maybe 9 ft. what kind of hammer would be best in such a small space. I know my hand hammer is probably best in that space but is there a maching that would fit in there? with my coal forge, propane forge, anvil, press bender, sander, power hacksaw, and quench tank space gets tight somwetimes buy carpal tunnel has me drooling for a power hammer.
July 14, 201016 yr Hey Grant don't joke now, thats the only way I can get my mill and lathe in my matchbox workshop Hey, you really weren't kidding. Looks like one of my custom installs...If it doesn't fit, no problem. Nothing that a bigger hammer won't remedy!
July 14, 201016 yr Im gonna think about that picture next time I want to complain about being cramped for space... Man David that looks a wee bit jammed in there... wee doesn't even begin to describe my workshop:)
July 14, 201016 yr Hey, you really weren't kidding. Looks like one of my custom installs...If it doesn't fit, no problem. Nothing that a bigger hammer won't remedy! ....or very long crow bars ;)
July 14, 201016 yr Hey Grant don't joke now, thats the only way I can get my mill and lathe in my matchbox workshop Think I might write an article on surviving in the small workshop for that Baptists website of yours This reminds me of when my buddy moved his milling machine into his moms garage and it fell over though the bathroom, breaking a few pipes and tearing out wiring at the same time nearly burning the place down He did get the machine for a really good deal though 300 bucks with some tooling and a vice. I guess this evened everything out lol
July 14, 201016 yr I have a question about power hammers..My shop is small, a 12x12 building with a ceiling of maybe 9 ft. what kind of hammer would be best in such a small space. I know my hand hammer is probably best in that space but is there a maching that would fit in there? with my coal forge, propane forge, anvil, press bender, sander, power hacksaw, and quench tank space gets tight somwetimes buy carpal tunnel has me drooling for a power hammer. The anyang 15 kg (33lb( has a footprint of about 16" x 36" if you want to go the self contained route. Im guessing the I.Kiss 50lb is pretty similar if you want to go 'utility' hammer. Basically either of these will take up less space than a flypress on a stand B)
July 14, 201016 yr The anyang 15 kg (33lb( has a footprint of about 16" x 36" if you want to go the self contained route. Im guessing the I.Kiss 50lb is pretty similar if you want to go 'utility' hammer. Basically either of these will take up less space than a flypress on a stand ....but the compressor footprint is? .......
July 14, 201016 yr ....but the compressor footprint is? ....... learning from yourself david.... either under a workbench or outside in a seperate shed :lol:
July 15, 201016 yr Don't laugh at the power hammer retard, but whats the difference between a utility hammer and self contained?
July 15, 201016 yr Author You can put the compressor on the roof! Been in shops in Asia where you had to decide what machine you were going to be using before you went in so you knew which way to face! Almost not an exaggeration!
July 15, 201016 yr ironstein - "utility hammer" refers to a penumatic hammer which depends on an external source of compressed air. Iron Kiss being an example. A "self contained" hammer refers to one that has a "compressor" cylinder built-in - an an yang or some chambersbergs, nazel, etc. So a utility hammer has plumbing for air from a compressor, but likely no electrical connection at all. A self-contained hammer has an electric motor. Obviously, any power hammer or hand hammer has "utility"...
July 15, 201016 yr You can put the compressor on the roof! Been in shops in Asia where you had to decide what machine you were going to be using before you went in so you knew which way to face! Almost not an exaggeration! on a pitched slate roof?:)
July 15, 201016 yr Author Just thinking of options, that one is obviously not for you. Up above the rafters maybe?
July 15, 201016 yr Wait a minute!You already have(at least) TWO pneumatic power hammers and two chipping guns. What are those running off of Mr Smarty Smith? Let`s just assume you don`t got a compressor.You got a hydraulic press,I seen it.Build a hammer like Poleframer made and power it with the same hydraulic pump system that runs your press.Then your can dial in the speed you want too.
July 15, 201016 yr basement...water heater shed attached to outside wall...outbuilding...many options to house a compressor. Phil
July 15, 201016 yr If young mr Dylan situated his compressor any place outside his workshop he would have to blow into his powerhammers like a man inflating a lilo the next day. Stockport, gotta love it (we once left a press tool weighing seveal hundred kilos in a heavily gated & barbed wire yard outside our old factory, in a similar kinda area to stockport, a few years back. One of the lads suggested putting it inside for the night, gaffer said 'duck it, if they can lift it they can have it..... I honestly thing the smack heads could build a pyramid in double quick time with no power tools if they were rattling and there was a bag of brown at the end of the job )
July 15, 201016 yr Wait a minute!You already have(at least) TWO pneumatic power hammers and two chipping guns. What are those running off of Mr Smarty Smith? Let`s just assume you don`t got a compressor.You got a hydraulic press,I seen it.Build a hammer like Poleframer made and power it with the same hydraulic pump system that runs your press.Then your can dial in the speed you want too. two hydraulic presses actually, 30 ton C frame and 15 ton H frame:) I've got a 10hp vane compressor, and it's ...... ....... housed in an old toilet nearby....... needs must ...... I'm sure Grant would appove, easier to maintain than on the roof:) One of the few concessions my landlord has ever given me. Used to be housed under my 8' by 4' workbench. Moving it out made a massive difference to me.
July 15, 201016 yr Author If it's any consolation, the problem never goes away. I had the same issues when I had 28,000 square feet of shop on 1 acre of land. How far away from the service do you want to put the 200HP air compressor at $100.00 per foot for the wire, conduit and install? 100 feet away? That's $10,000.00 that you coulda taken home. Ended up nearly 200 feet away! And then you start plumbing.
July 15, 201016 yr Author Or when someone "gives" you a hammer and it costs $5,000.00 to take it out and transport it and requires a $40,000.00 foundation? But it was "free"!
July 15, 201016 yr ironstein - "utility hammer" refers to a penumatic hammer which depends on an external source of compressed air. Iron Kiss being an example. A "self contained" hammer refers to one that has a "compressor" cylinder built-in - an an yang or some chambersbergs, nazel, etc. So a utility hammer has plumbing for air from a compressor, but likely no electrical connection at all. A self-contained hammer has an electric motor. Obviously, any power hammer or hand hammer has "utility"... kinda odd term really, I always take the word utility to mean services such as gas/water/drains/electricity/maybe air. In that sense a self contained is also a utility hammer. ......and the definition of pedant is?
July 15, 201016 yr Author I believe Chambersburg coined that. They called their little one-piece steam/air hammers "utility hammers". That's my story and I'm sticking to it! No pedantry 'round here!
