hank57 Posted August 26, 2009 Share Posted August 26, 2009 being new here i have a problem. i've been looking for 2" pipe to build a tire rim forge with 2" black pipe under the rim for my blower to hook up to. lowes and home depot only have 2" galvanized pipe. the best value hardware store has the same thing. is there something else i can use ? thanks henry Quote Link to comment Share on other sites More sharing options...
CBrann Posted August 26, 2009 Share Posted August 26, 2009 Check at a plumbing supply house.... what are you doing with it? Quote Link to comment Share on other sites More sharing options...
hank57 Posted August 26, 2009 Author Share Posted August 26, 2009 i'm trying to build the air flow part.under the rim. it a rim with a stand and the 2" pipe will be hooked up to a blower to force air under the coals. henry Quote Link to comment Share on other sites More sharing options...
unkle spike Posted August 26, 2009 Share Posted August 26, 2009 Check auto parts stores for 2" exhaust tubing, it is galvanized, but a grinder will take care of that. The pipe "shouldn't" get hot enough to matter. I have a galvy one on mine and the coating looks as good as the day I put it on. Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 26, 2009 Share Posted August 26, 2009 Check the dumpster behind the muffler shop. Ask nicely and you might get the new short pieces they discard as well as the entire length of the old pipe that was just removed. Tell the fellow what you want and buy him lunch and he may weld the T into the down pipe while your going for the burgers. (grin) You may want to review BP0133 55 Forge for some ideas. Quote Link to comment Share on other sites More sharing options...
hank57 Posted August 26, 2009 Author Share Posted August 26, 2009 so if i use galvanized it should not make that much of a difference? they do have gavanized at the hardware store. henry Quote Link to comment Share on other sites More sharing options...
petere76 Posted August 26, 2009 Share Posted August 26, 2009 Hank, As a safe operating practice, consider not using fittings pipes and fasteners that are galvanized anywhere where they will be exposed to high temps. The thermal break down of the zinc poses a fume posioning hazard and the results can be deadly or debilitative. Always keep in mind that we are the last safety check in our shops. Peter Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted August 27, 2009 Share Posted August 27, 2009 The way that the folks at Durrett Sheppard Co. explained it to me was that "pipe" is a steel tube that has passed testing for pressure and that "tubing" is basically the same pipe that has not been tested for pressure. So what you are asking for when talking to a place like Durrett Sheppard is "unplated 2 inch ID structural *tubing*". On the other hand Boulevard Sales in Baltimore only sells structural materials and told me to call it "black pipe". Untested structural grade tubing is likely to cost less than tested black pipe. So I would humbly suggest calling around to the places that sell structural materials and ask for "2" diameter black pipe or 2" diameter structural tubing". :D Quote Link to comment Share on other sites More sharing options...
hank57 Posted August 27, 2009 Author Share Posted August 27, 2009 ok all. thanks for all the good replies. will keep calling locally. thanks henry Quote Link to comment Share on other sites More sharing options...
jimbob Posted August 27, 2009 Share Posted August 27, 2009 you could always use a line post for chain link fence from lowes or home depot or a company that installs fence ...also you could use 3 inch made of sheet metal for vent pipes for gas water heaters sold at the hardware store Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 27, 2009 Share Posted August 27, 2009 The pipe under the fire pot is not going to get hot enough to burn off the galvy unless you build something really odd. Seriously, zinc doesn't burn till it's middlin orange hot and that ain't going to happen with air blowing through it. You can also get unplated mild steel exhaust pipe. Frosty Quote Link to comment Share on other sites More sharing options...
CBrann Posted August 27, 2009 Share Posted August 27, 2009 Isn't some stove pipe galvanized.. and I have seen plenty of it get plenty warm from a wood stove without burning the zinc .... Disclaimer... just a personal observation!! Also if you look for structural tubing, be ready to give a wall thickness in decimal inches i.e. .125 inches is 1/8th inch thick... thinner might be better... .... how about looking for schedule 40 steam pipe.. threaded, not bolt or weld together.. its non galvy... Good Luck, Cliff Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 27, 2009 Share Posted August 27, 2009 Stove pipe is stainless or black coated. Galvanized duct is for forced air hvac. Getting non-galvanized pipe and tubing in larger sizes is hard if you haven't looked into the contractor supply houses - that is non-big-box stores. Phil Quote Link to comment Share on other sites More sharing options...
hank57 Posted August 27, 2009 Author Share Posted August 27, 2009 thanks everyone. i just went ahead and did the galvinized 2" worked great. now to start making my 1st rr knife. will do that this weekend. thanks henry Quote Link to comment Share on other sites More sharing options...
meinhoutexas Posted August 28, 2009 Share Posted August 28, 2009 Hank heck i wish i had read this post earlyer! i have abunch of stuff to build forges. Drop me a note next time you are scrounging and ill bring you out to the scrap pile and go hunting. I work at a shop that reclames the halon out of the BIG fire bottles in computer rooms we get all kinds of pipe,and just plane stuff. Quote Link to comment Share on other sites More sharing options...
hank57 Posted August 28, 2009 Author Share Posted August 28, 2009 Thanks meinhoutexas, we need to do that.sometime. hopefully you can give me a tip or two. i work down the street from you on i-45 and el dorado.let me know when it would be a good time for you. thanks henry Quote Link to comment Share on other sites More sharing options...
meinhoutexas Posted August 29, 2009 Share Posted August 29, 2009 Hank to cool! i am curently learning under a smith down in santa fe. all the work i get to do is down in his shop. But i am sure he would like to meet you. We will definantly need to make some time to b.s. soon. If you need a old high pressure tank bottom to make spoons or bowls let me know i have a few that we can cut up. Quote Link to comment Share on other sites More sharing options...
hank57 Posted September 8, 2009 Author Share Posted September 8, 2009 so after 2 heart attacks in the last 5 yrs.and 7 stents later the dr. keeps tell me to walk every day for 30 min. i have done and its borring. so i don't do it every day. well i found out this weekend that forging a knife is just as good as walking those 30 min. if not better. i did not know how hard it was to beat the heck out of a piece of steel to make it look like a knife. i got my work out that day. to tell you the truth it even felt good the rest of the day. as soon as i get pic taker i'll put up some pics. thanks for the help guys. henry Quote Link to comment Share on other sites More sharing options...
meinhoutexas Posted September 9, 2009 Share Posted September 9, 2009 henry what part of town are you in? i am in the subdivision behind kroger on 45. if you want i have an old fire plug sitting in my front yard you may have for a swage block if you want it. have no clue as to if it will work and ill help you pick the darn thing up! got it in austin back when i worked road construction. Quote Link to comment Share on other sites More sharing options...
kashmire Posted September 11, 2009 Share Posted September 11, 2009 make friends with a your local HVAC company most of the scraps they find useless i find fantastic, i get all my black pipe from them. if they do old boiler rip outs and stuff, tell them to call you with where it is and you can get all kinds of stuff. Quote Link to comment Share on other sites More sharing options...
hank57 Posted September 12, 2009 Author Share Posted September 12, 2009 kashmire thanks for the info. i'll try that. Quote Link to comment Share on other sites More sharing options...
hank57 Posted September 12, 2009 Author Share Posted September 12, 2009 thanks meinhoutexas. just sent you p.m. henry Quote Link to comment Share on other sites More sharing options...
hank57 Posted October 2, 2009 Author Share Posted October 2, 2009 meinhoutexas, thanks for the items you brought over. nice. it will come in handy. let me know about the tank to build a forge with. i'll have to make one. thanks again henry Quote Link to comment Share on other sites More sharing options...
