August 7, 200916 yr Does anyone know of a good igniter system for a gas forge? I am using a propane torch now but would like to install a good igniter system. Richard
August 7, 200916 yr Most of the ones I have seen are gas grill units. Don't use one here. Light mine from the top with a butane lighter. Ken
August 7, 200916 yr If you do a search for Piezo Ignition Kit, I think you will find what you are looking for.
August 7, 200916 yr I just use one of them long neck butane lighters, designed for lighting gas grills and stoves. welder19
August 11, 200916 yr i use a piezo button attached to a spark plug that i cut the ceramic down on, however sometimes it takes too many button pushes to get the job done, so in a hurry i just use my propane torch. :)
August 11, 200916 yr I'm with barcrawler - My piezo/sparkplug unit is cranky about igniting the forge so I just use a propane torch.
