April 11, 200917 yr I made these and thought I would share them with you all. I made them outta 3/8s Rod , and I'm hoping the next pair will be better. These will work. But it was so much fun making them..I think I'll do it again.. Need to put some oil on that table..
April 11, 200917 yr An easy way to make small but strong scroll pliers is to grind the jaws of a set of linemans pliers.
April 11, 200917 yr They look pretty good Tom, need a little smoothing and radiusing in the jaws but that may be the picture. Frosty
April 11, 200917 yr Author Thanks ,, Yea I need to align them alittle better, And I said I made them outta 3/8s I actualy made them outta 1/2 rod..
April 12, 200917 yr Good work Tom. I'm getting my forge prepared for it's (my) first fire up. Looks as if I'll need to make a lot of tongs myself.
April 12, 200917 yr Tom if I knew how to send a picture of the pair worked on today you would get a good laugh. Want to swap? your's look good. Dave
April 12, 200917 yr Author Thanks everybody.. I had so much fun, I'm thinking of making another pair today.. But before I do that I'm going to try again to forge weld. Tinbender If you need help with picture's or anything on here.just hollor be glad to help you out.. and if I ain't availible.someone else will help..
April 12, 200917 yr Tong Day myself here, am working on "sets" of different size ones. Presently I am on box jaw tongs for flat stock. I don't put much "spit and polish" into mine, just utilitarian tools, not a work of art. Yours look real good Tom, they always need some hot tweaking to get them to fit just right. One trick I learned at our guild: When you set the rivet, while they are still pretty warm, dunk them in the quench tank and work them, seems to set the rivet to the right tension. Yes I know some say never quench hot tongs it makes them weak, have only had one set I made fail, and that was because I got them too thin at the jaw joint. Edited April 12, 200917 yr by unkle spike
April 12, 200917 yr Tom, good job on the tong/pliers. The great thing about making your own is that you can 'tweak' them any time you want to (if they need it). And yes.....I have tongs that I've made that have been 'tweaked' many times over the years. I wind up using mine for pickup tongs more often than for actual scrolling. they're handy for chasing small rivets and other small pieces down through the fire. James
April 12, 200917 yr Author Thanks James . Yea I was going to try and do some forge welding, but the bee's hive wasn't working out. or I just got in to big of a hurry, I dug it out and the fire just wasn't right. after fooling with it for a good while I said the heck with it and started making another pair of plyers. I got them started then the wife lets me know easter diinner was ready so I closed her down.. I reckon we'll be back at it when I get in off the road. Sure had some fun... Happy easter Boy's...
