47,373 -
Everything posted by Frosty
Those are cool though I'm not sure what I'd use them for. Still. Agreed, NEVER pick up stuff along the rail road! Frosty The Lucky.
Frosty replied to Mark Ling's topic in Blacksmithing, General Discussion
The next total eclipse touching the US is supposed to cross Alaska in March some 20 years from now. No idea what part of AK though so I'll keep my fingers crossed. Frosty The Lucky. -
HAH, I didn't have any of those problems, the closest an edge of the penumbra came to us was about 1,000 miles. It was sure good watching on TV though, some really awesome pics. Does anyone out there in Iforge-land know why the solar corona changed colors like that? Frosty The Lucky. -
Did you make ulu shaped pole flensing knives to go with? How much blubber did they get, a toner two? Frosty The Lucky.
Welcome aboard Plaasjapie, glad to have you. If you put your general location in the header you'll have a MUCH better chance of meeting up with Iforge members living within visiting distance. I believe we have members in S. Africa but I don't remember where. I can make a few suggestions even though I live on the far side of the planet, literally. Do NOT wait until you collect what you think are the necessary tools, all you need is a hot fire, something to beat against and something to beat with. Something to hold onto HOT steel is a good thing but until you find or make tongs use a piece of steel long enough the end you hold onto doesn't get hot. This is actually referable to using tongs when possible. A wide bladed masonry chisel works well enough to cut HOT steel but keep it cool. What do you have in mind for a forge? Iforge has sections about all kinds of forges, solid fuel, propane and methane fired. Being able to get together with an experienced smith is the best way to learn but we like helping folks along so give us a shout too. Frosty The Lucky.
A memorable gift is the best kind! How long did it take to pull it out of the copier? Frosty The Lucky.
Right you are John!, Whoever suggested screw on pipe caps on both ends wasn't thinking when he wrote that! Frosty The Lucky.
Both look good from here the refractory is high alumina so should be resistant to hot flux erosion and the zirconium refractory looks like a good kiln wash. I would definitely use the zirconium silicate wash rather than a home brew! You should NOT need fire brick for a floor, you can lay a coat of both these products over the current one if necessary. It says so in their literature. I clean flux puddles out of my forge if they become an issue by putting on a couple layers of leather and wire brushing the forge floor at high orange heat. Dropping the gooey brush in the slack tub removes most of the borax, dissolved brick and scale goop on the bristles. Frosty The Lucky.
Oh MY! You should've contacted Harbor Freight as soon as you struck that. . .No, not ASO it's no longer shaped like an anvil. It's not even gray cast iron. Yes, even a smooth boulder would be a step up let alone an injured good quality anvil. I would counter offer less in person while holding a handful of bills. I don't use the horn on my Soderfors much, sometimes as a bottom fuller and rarely to true up rings but that's about it. I do 99% of my forging on the face or a bottom tool. Frosty The Lucky.
Huh, it's April and only gets dark for a couple hours and soon twilight will be it. I can't control the moon so I'll bring a flashlight. Frosty The Lucky. -
I remember now, I haven't watched ARS in a couple years. PBS lost us when they went commercial. It was a place to take things to be appraised there was an episode up here, it was fun seeing so many familiar faces. We're typing at the same time again George. My memory is coming back about the show, a reminder or two was all I needed. Thanks all. How's the weather? Sunny and heading for high 30 - low 40s here. Frosty The Lucky.
Oh NO! You definitely need the larger drill bit and more powerful hand drill, no doubt, The extra area between legs and hole will improve it's solidity! Good catch John, I'd HATE to steer someone the wrong way! Frosty The Lucky. -
What a story John! Why did she give up a family heirloom like that, did she say? I only have a couple things of my parents and one from each Grandfather. They never knew each other, even remotely but both gold watches are virtually identical, they even have the same cloth bag with draw string. They were bought probably 40 years apart, one well after my paternal grandfather had passed a victim of the 1918 Spanish flu pandemic. I've looked them over closely and there's no way to tell witch was who's. Frosty The Lucky.
E X C U S E ME!!! Did I just read a BLACKSMITH say a piece of steel was a LITTLE too large so he'll have to buy another drill bit?!?!? Good GRIEF Billy, how about heating the legs up and drawing them down till they fit? Or maybe better, chisel the corners off them till they fit, and leave a snagly rough finish so the lead has tooth to stick to? You know if you do a simple copper plate on the parts of the legs that'll be set in stone, you can apply a little soldering flux and the led will bond to them like brazing rod. Frosty The Lucky. -
This side of the Atlantic we call them a "muffle" but that's just a name. Use kiln furniture to support the blade. Support the muffle off the floor of the forge / furnace for the same reason as well. Seal the pipe nipple with screw on caps drill, a small pinhole drilled in one of the caps so it doesn't become a pressure bomb. Put a little lump charcoal in the muffle, it WILL consume the free oxy and so long as it isn't touching the blade won't effect it. Read the temp of the muffle, there will NOT be enough difference between the inside and outside of the steel walls to matter. This is pretty simple process and has been done since steel has been used in a hardened state. To improve your process stop over thinking it. You can NOT control every aspect without maybe hundreds of thousands of dollars worth of equipment and instrumentation. Frosty The Lucky.
HGR site doesn't like me, it stopped letting me sign in and since then says I already have an account and won't let me open another. I get no response trying to them contact either. Frosty The Lucky.
And now I know what a "tool balancer" is, I can think of a number of things one would be handy for. Thanks John, Lounge well my friend. Frosty The Lucky.
I replied to one of your other requests for the same thing! Did you even do a web search for "II&B Co. anvil"? . . . "Illinois Iron & Bolt" is the first hit. I'm not going to search through their website or catalogues for you, it won't help you learn how to learn. I enjoy helping folks and answering questions but you have to do something for yourself first. You have the internet available, all you have to do is a web search. Of course doing a good web search is a learned skill, just like blacksmithing. And taking decent photos for that matter. Whatever you may wish to know about your anvil will do absolutely nothing for learning to be a competent blacksmith, that requires different questions and time at the anvil. A little knowledge and a LOT of practice is the secret. Now, go forth build a fire and beat some steel! Need a hand give a shout. Frosty The Lucky.
Welcome aboard Jody, glad to have you. If you put your general location in the header you'll have a much better chance of meeting with members living within visiting distance. This is the second post you have asked exactly the same thing and provided really poor photos to go with. Asking the same thing in multiple posts will not get you a quicker or better answer. What it is likely to get is a note from a moderator about wasting bandwidth. How about telling us something about your anvil. What does it weigh on a scale, what does it say it weighs if the weight is stamped in the side? Width $ length of the face? Condition of the face and edges? Rebound? Pattern, weight, condition and rebound are the 4 main factors determining an anvil's value as a tool. Unless your prime focus is a particular brand or age. Learning to take good pictures really helps, I can not read what is cast proud on the foot. Okay, I just tried to get a better look on your other post and it's closed or perhaps deleted already. What are the characters on the anvil's foot? and how about a couple pics of the whole anvil, one from the side with the face plate visible would be nice. Frosty The Lucky.
Tool . . . Balancer? Dang, now I can't think of what we called them, something like recoil lanyard, call or come back? I vote we rename your Theater dumpster John's treasure trove #1. How many dumpsters are a regular host? I mount most of my top tools on old hockey sticks, I picked up 8-9 from a high school trash can next to the gym door. I used to have free reign at the heavy duty shop dumpster till a guy at a different camp got greedy and started throwing brand new tires in the light duty dumpster and picking them after work. Someone noticed his rigs had brand new tires, took a look and that was that. Private citizens can NOT buy new Cop tires. That was it, dumpster diving became a firing offense for any state employee so I no longer got to bring home scrap steel. Fuel truck delivered day before yesterday and left some deep ruts down hear the shop. Mud season begins. It's the good bad of spring, warms up ground turns to mush. <sigh> Frosty The Lucky.
Celtic towel torcs? . . . Dang, where'd THAT thought come from? Frosty The Lucky. -
No picture? Depends on why it doesn't have a horn. Was the horn broken off or is it a hornless pattern? What about the rest of the evaluation? The condition of the face and edges? How about it's rebound? Do you use a horn, if so for what? My Soderfors has a beautiful horn and I rarely use it for anything but a bottom fuller on occasion, It's edges have two different radiuses and I can do almost all my fullering on them. I's use the horn for truing up rings if necessary. $200 for a 150lb anvil sounds like a great price if it's in good enough condition. Post a couple pictures and we can give you more informed opinions. Frosty The Lucky.
I was thinking a sea serpent, I could cut it in lengths for the above ground parts and make a larger Wyrm. Frosty The Lucky.
He's also wearing more sandals than the low top shoes the others are. Then there is his hat, though I know nothing about hats it sort of makes me think Tyrolean sort of. What about the fellow sitting in the lower right with the basket of . . . things that look like cloves of garlic? Is he selling nibbles for the event everybody is gathered to watch? I dipped my toes in the Torc rabbit hole and watched a few "Curator's Corner" videos from The British Museum. The lady was discussing the Snettisham great torc, first pic in the link about torcs. She described how gold was poured into a bar then forged longer and longer until it was the wire in the torc from the hoard. Of course NOBODY knows how it was made, then she goes on to describe what she imagines it took to cast the ornately decorated ring ends onto the twisted wire body and the collars between were to hide the join. HAMMERED more than 200' of wire to precise dimension to make the 64 strands in the yarns in the "rope" main body! It illustrates my amazement at how many museum curators guess at things they have no grounding in rather than ask someone who does it every day. How many gold smiths would she have had to ask to learn about drawing wire? I tend to snoop around museums for blacksmithing or metalworking displays and offer advice for their displays if it falls in one of my areas. When the curator was interested, large museums often require college degrees to have an expert opinion. Drats drifted into a rant anyway. Sorry gang. Frosty The Lucky.
Good save John! There appears to be a signature in the bottom right but it may just be some of the random detail, filler on the ground. I'm wondering about the subject, the fellow standing with his hands behind his back doesn't look happy and that's a lot of spectators and a musician for a non-event. Who brings young children to watch a smith work on a normal day? There isn't much of a fire in the forge, nor an anvil or other smithing tools. If they were branding an outlaw I'd expect a different crowd and if they were closing his manacles I'd expect an anvil and guards. I don't know what's going on or why but I like it. Frosty The Lucky.
