Everything posted by Sweany
Posting Courtesy
SO, where is the Luchroom? :)
Railroad rail
thanks Frosty. 80lbs a yard it is. ***** EWCTool. you must have wanted it pretty bad!
Railroad rail
what a minute, how big a boy are ya! 12 ft of rail is pretty hefty. line rail is around 80lbs a foot IIRC
Railroad rail
Link removed at the request of anvilfire check out the RR tools tuttorials
Chimney Fire Paranoia
Why don't you try to burn the coal soot? :)
Kevin in NY Times - catching liars
Congratulations! keep up the good work.
Corn as Fuel
well geee Andrew. This one works well. Don't knock it unless you've tried it.
Corn as Fuel
QUOTE"What we really need to be working on is a coal making machine. . . Caleb Ramsby " Quote we live on a coal making machine... My experience with charcoal is the deeper the better. Mine was fashioned after Tim's but I used wood instead of a washtub. It worked great. I also found wetting the charcoal as you do coal (while the fire is burning) kept the fine sparks down. the Tube type tuyre really works very well I was skeptical at first. Charcoal Forge If you go with the biomass, the added depth of the firepot will increase your charcoal conversion,as new uncharred fuel is added to the top, it is preheated and cooked. I spose a draft hood could induce the cooking gases back into the fire? Personally I'd prefer charcoaling as aseperate event. Seems to me less loss of heat as the conversion is going on. I like Daniels idea and used it succesfully to make charcoal of pine scraps and oak pallets. His use of gasification to fuel the charcoal conversion was very inspireing. I did not use his Kiln of blocks but instead used more brush that needed some usefull way to be gone. Making Charcoal
- Portable Forge
Who needs a plasma torch?
just for fun Steve....
BB Video: The Flaming Bacon Lance of Death, from Theo Gray's book "Mad Science" - Boing Boing
anyone out there from Amarillo or Lubbock
check this out Saltfork Craftsmen
Nails
Bruce Lee does blacksmithing. :)
Damascus Mike
what divermike said:
- Bladesmithing techniques?
Humbling Experience
As my old neighbor lady would say. "You'll do better when you know better"
making itc 100
Here's the lin to the MSDS sheets for the ITC products. ITC-100, ITC-200, ITC-213 Ceramic Coatings
Forge info
Muffle - Wikipedia, the free encyclopedia
Gas Burner Ignition
all the forges I have seen with built in ignitors have been in the burner tube just before entering the forge as you have said. there should be little heat there after the ignition as the flow will cool the ignitor. I've seen both the standard BBQ ingitors and sparkplugs used. However the sparplugs have a better coefficient of COOL about them.
kaolin clay
Axner Pottery and Ceramic Supplies
Flint strikers as art?
Yep I'm Sweany. good to see ya bro.
look at my stuff
Oliver hammer
Introducing: my first hammer
Welocme. Nice Hammer, did you use a wedge on the handle? Does the sand help the tar hold onto the handle? I never heard of this method before. I'd like to try it.
sucker rod carbon content?
Thanks Thomas I didn't know that
how to straighten a semi-finished blade
I've water quenched 5160 like the Kukri makers. You gotta be fast to quench both sides of the of the edge, or you can wind up with one side harder than the other. Check the hardened edge with a file, then temper.
