Chad J.
567 -
Everything posted by Chad J.
Chad J. replied to Mark Ling's topic in Blacksmithing, General Discussion
A friend challenged me to make a knife from a wrench. I just happened to have a 7/8ths laying around and took it as a speed challenge. -
Wow, thanks! It means a lot coming from you. -
I'm always reluctant to post after Alexandr. His stuff is simply amazing every time. I'm almost out of round stock and my steel yard is currently closed on Saturdays, which I just found out today... Anyway it's been a blade day. I have several that have been leaning against the wall along with a new arming sword I just started. I think I may start normalizing for a heat treat today. Well, at least the ones that can fit in my oven. The kukri actually started as another xyphos that I messed up the handle. -
The place that will fill my hundred pound propane tank had been a pain to get to, closed on Sundays and by 5 so I've been doing finish work as long as I can stand to be in the shop. I did my first stacked leather handle on Monday and did some shaking on it last night while also starting the finish sanding on the blade of this side dagger. -
Got to see Ric Furrer demonstrate his method for making wootz steel this weekend at the UMBA winter conference. Really a lot of fun. -
If ya need a tool, make a tool
- 9 replies
- coil spring
- tooling
Knocked out a quick spring fuller last night with 3/4 round welded on for the fullers. I ground them down a bit to be flatter as I well be using these for blades when I get that urge, which is actually really frequent. I also started a new Oakeshot 12 the other day. Learned my lesson on the first and started much closer to what I wanted my final measurements to be. So I got the blade rough forged in about 4 hours as opposed to 2 weeks. Started hammering the fuller and it's looking great. -
Love the shape and handle. How tough is that coal to work and can it take a beating?
Nice find, I'm curious why he's wearing a lab coat in the picture though... Went up to St Paul to visit my oldest daughter over the weekend for a late Christmas. She got me a really nice new shop apron. Stopped by a Half Priced Bookstore where her boyfriend works and found a few books.
My ADHD turns every last flat surface into storage, and my focus is equivalent to a sawed off punt gun shot. I do generally put things in the same place but short of having specific plans or goals, my pile of in progress projects has spilled from the rack by my anvil to my tablesaw, grinder table, top of my forge, on my coal forge, the floor under the forge, and any other flat surface including in my kitchen and kitchen table. I have the room and will be putting in some dedicated work benches but propane is currently expensive...
Did my first square knot. I can probably tighten it up a bit more but it was getting late when I jumped onto that project and I needed to get dinner in. Made a couple hearts on the end to make a brooch with a matching pin. -
That looks like a fun build Billy. How long did you make the tined?
Thanks for the ideas guys, I need to make a bridge some time soon. I bent the tines it off the way and worked them on the horn and corner of the anvil. Got it close to what I envisioned. I can spend some time refining and it'll be goid i think. I think I'm going to cut 5 more out for practice.
Ran out of propane before I got too far, i may start over because I can only get three fingers in it. Part one went ok. It's still 1/4 inch thick so I have room to play with. Odds are I need to start with a slightly wider piece and a wider gap between the tines.
I'll post the drawings and take pictures. I think I may need to do these on the coal forge due to size.
I've been drawing out how to do a set of bear claws for pulled pork. I was planning on starting with some 3/8 × 2 bar stock, cut and shape and put on some wooden handles. For the life of me I can't find forged versions on the internet. Maybe figure out how to get a bottle opener on it. Anyone made a set?
Hey Bug, welcome! I have an issue with bottle openers, every time I make one I have to test it. My liver gets mad at me for it. That's a great first opener. How did you drift it open? My first bottle openers were curled and it took a hammer in for me to learn how to do punched and drifted openers.
Shainarue tongs are something you improve on a you do them. My first 2 sets are ugly, 3rd was better, and the 4th set is great for smaller stuff. But I also have multiple sets laying on the table because I didn't like how I forged them or I made them left handed. -
Thanks George.
Not having a lot of hair myself I took it to work and I was told it was a bit heavy, I'll use a smaller starting stock and try again. -
Made a couple barrettes and hair pins last night. Propane was getting low so I was keeping it simple. -
I have one again let my hammer overtake my senses in pushing myself on challenging blades. This time I have a rapier blade blank that is 42 inches on the blade itself and currently 49 inches overall. 5160 1/4 × 1 inch at the base tapering to 1/8 inch at the tip. I have 2 options, 1; I go to another shop that has a 5 burner forge and bring the quench tank I'm going to build for it or 2; I do a trench forge with an air pipe and charcoal and laying the blade itself on a piece of angle iron to help keep it straight and heat evenly until I quench. I will have a straightening jig ready to go in my post vice and I'm probably going to have to torch temper to straw. Any tips or suggestions? I'm looking for holes and potential problems so I plan for them.
Often times I'll go on etsy and research design ideas, also helps me when I'm setting prices. I need to make a full set still.
Made my first and second orchid yesterday, only the second one survived me trying to attach it to this hair pin. I need a TIG welder... Cut it out on the bandsaw, cold shaped it, and welded it together. Hot brushed brass finish. -
Horseshoe Hearts for Valentines Day
Chad J. replied to ThomasPowers's topic in Blacksmithing, General Discussion
My first attempt looked like a heart that had been broken. Maybe I'll try again.
