mARTin Metal
    29
Profile Information
  • Gender
    Not Telling
  • Location
    Sonoma, California
Recent Profile Visitors
1,475 profile views
  1. I found a number 10, Norton Flypress. I’m looking for info and support documentation. On specs. Etc. I have not had any luck with an internet search. Thank you in advance. Any referrals would be appreciated.
  2. Wow, great read! Wealth of information and history. Thank you for your time knowledge and generosity. much Appreciated !
  3. So, lucky me. If you hit enough estate sales your bound to find treasure. Paid $200. For vise and all items pictured. Love the ornamental lines and detail on this Peter Wright. Excellent condition. Complete. No visible signs of abuse. Threads have full profile. Looks to have been parked and unused for decades. Thread box marked with maker, but some style of ornate logo in center of maker I.d. Note that the legs are not chamfered. My question is regarding age and provenance. Any historians wanna make an educated guess as to age?
  4. Why does content need to be approved by a moderator.
  5. Thank you all for your prompt and useful information. I will suggest the rebound test for the anvil. How would they heat treat temper the anvils when forged. I’ve heard the top plates were forge welded to the forged anvil body. Where they then oil quenched or slow cooled in an annealing furnace?
  6. I met a smith who lost his home and shop in the California wild fires. Depending on the location of the tool in the fire, what might be the expected damage to the steel with regard to tempering or annealing? Anvil on a burned stump, hammer heads with handles burned off. Tongs? What might be the general consensus on “repair or re tempering”? Fire survivor Anvil and hammer heads? I’m thinking it really depends on the temp and duration of exposure in the fire. Would the hammers and anvil be softer as a result of the heat? He might need to straighten the reins on the tongs, but I think they might be ok. Any thoughts or recommendationS.? Asking for a friend. TIA,
  7. I just picked up a 4” warren tool and forge, qwik werk vice that I would like to build a collapsible stand for travel. I saw a previous post with a suggested design, but now I have to re find it again. Anyone have any experience with this design. I think the picture I saw had three legs that swung up inline with the post, hinge pins at bottom of base.
  8. Darn. Just sold out from under me. Still, a strange make and model. Thanks Thomas, i only had the one picture and was unfamiliar with the shape of the foot and the solo Pritchett hole centered in place of the hardy hole. At this point, since the Anvil has been purchased by another party, now I’m just curious about the brand. I’ve used the rebound test on my working anvils. I’m getting close to 100% rebound on first bounce, then 95%, 90% etc. hard to measure a moving object. Now imagine holding a camera set on slo motion capture, a tape measure and dropping a large ball bearing onto slightly uneven surface, then catch the ball bearing before it shoots off the side and rolls under the drill press. Rebound test should be performed by a circus juggler.
  9. I came across this ad for an Anvil with misc tools for $200. I have not seen and Anvil like it. things to note in identification, with this only photo, no numbers, size or brand. Looks to be about 100# or less note narrow base or foot. single oversized Pritchett hole in place of hardie hole. looks to be cast with horizontal casting part line and hard face top forge welded on or in casting? anyone seen something like it? Darn. Just sold out from under me. Still, a strange make and model.
  10. Thank you Thomas, I enjoy hearing from you. be well, we need you.
  11. Iron dragon, that’s a good idea! I made my stand to fit layers of Marine grade plywood. So I can adjust the height for different users. I’ll “glue” ( removable) to one layer and use one or two plywood layers for height. I’ll have to make my holdowns adjustable. The Anvil is only 80# so it is a bit lofty in full use, but with the holdowns sandwiching the dense plywood it might work ok. Thanks, I’ll give it a try.
  12. Thank you Thomas Powers and Iron dragon, your help and advice is much appreciated. I have worked in both Foundries and Forges, not my first job nor my last. Reminds me, someone told me “All Farriers are blacksmiths, but not all Blacksmiths are Farriers” I used the term Foundry as a ubiquitous term for Forge, when I knew there is a difference. Let’s not bring up “Smelting” It’s best to use precise terminology when seeking answers. Something else I am working on. Thanks Thomas.
  13. Yes I do, thanks Glenn
  14. Columbus iron and forge, good tip. I’ll check it out. I have found ear protection to be the best sound suppression. I’ve tried magnets that deadens the sound well, but the slag sticks to the work face. Chain adds more weight and reduces ring, but gets in my way. thanks for the reply
