Everything posted by Frank Turley
Asking For The Experts
Yes, check out the Pennsylvania Artist Blacksmiths Association (PABA). You're in a great area for visiting Hopewell Furnace National Historic Site, the recently built Moravian Smithy in Bethlehem, and The Mercer Museum in Doylestown. And that's just for starters. Turley Forge and Blacksmithing School
Right angle bend formula
A couple of thoughts. If you stack two separate pieces together at a right angle corner, say one of 15" and the other 10.5", you'll get your stock length of 25.5". If you measure the neutral axis, you'll get the same measurement. Staying on the neutral axis for the center punch mark, drop back 10.75" from the short leg end leaving 14.75" for the long leg. It's easier to visualize if laid out on graph paper. We're doing simple arithmetic, but it is nevertheless ballpark, because everyone works differently and at different heats. Test pieces are in order. Another thing I often consider, because I've made lots of turned heels (calks) on horseshoes. I try to think about where the inside of the bend will be when I start. On an upset corner, you'll finally gain length, about the thickness, on the fixed piece you're holding. You'll gain it measuring from the inside corner because of the stock material in the bend itself. I assume this is an "upset corner." If it is, one way is to bend, and to keep the bend at about 100 -105 degrees while using friction/drawing blows to draw metal to the outside corner. You'll gain a little thickness which you can correct as you go. Toward the end of the forging, little by little, close the angle to 90 degrees trying to keep a shut from occuring on the inside corner. Buena Suerte Turley Forge and Blacksmithing School
What is a Master Blacksmith?
I was traveling with two friends through Scotland not too many years ago, and stopped to see an elder smith in Closeburn, Scotland. The man was Edward Martin, now deceased, who had probably shod more Clydesdales that anyone on two hind legs. He was also a fine artist blacksmith, and he drove us to some surrounding villages to show us some of his work, most of it in and around churches. Visiting in his living room, he brought forth a gold medal, perhaps 3.5 inches in diameter. He said that he had been called to London in the year 2000 by the Worshipful Company of Blacksmiths. He was presented with the medal, reportedly only the fourth such award to be given in the history of the Company. Edward said it was the third given in the last 100 years. On the medal was written, "Awarded to Edward Martin, SUPREME MASTER BLACKSMITH." 'Nuff said! http://www.turleyforge.com
Striker Hammer handle length
If you strike the most used European way, the haft should be between 20" and 25" depending on a person's height and build. Also, remove the varnish, or whatever it is, from a newly purchased haft. Take it to bare wood. I use 1/2 turpentine and 1/2 boiled linseed oil mixed and rubbed in well for a finish. By European method, I mean lifting the hammer up and swinging it down in it's own arc, not too unlike the way a hand hammer is used...except you're doing it two handed. No sideways swinging and no sliding the hand on the haft. There is such a thing as a full around swing where both hands are near the end of the haft and the swing is circular by the side of the body. In that case, the haft can be longer than 24". Turley Forge and Blacksmithing School
brake drum forges
Save up some money and buy a firepot.
Case Hardening and alloying
Re "beating the crap out of it," that notion comes probably from Longfellow's, "The smith a mighty man is he with arms like steel bands." As a teacher of smithery, I continually encourage the macho oriented, muscle bound student to use finesse, finesse, finesse. http://www.turleyforge.com
Window Weight Material?
Use them for sheet metal stakes. Turley Forge and Blacksmithing School : The Granddaddy of Blacksmithing Schools
Welding onto a hinge
I don't have a good name for the weld, but is is similar to a T-weld, but done on the diagonal. I asked Francis Whitaker to do the weld years ago, because I really didn't know how. I will call the attached part "the branch." The branch was cropped on the end at a 90
Farriers
Our old farrier instructor told us that if you quit shoeing, it's for one of two reasons: you didn't get along with the horses or you didn't get along with the work.
Farriers
I began as a farrier in the early 1960's, and charging ha ha $11.00 per head for hot shaping, fitting, and nailing on keg (manufactured) shoes. Yeah, really!...and that was good money at the time! I really don't know what the deal is today, maybe between $80 and $125? I never did more than five a day, because my body told me to quit while I was ahead. Shoeing is strenous work. I've met shoers who said they did 30 a day. Then later I found out that the shoer had a helper and both of them only trimmed 18 that day; none were shod. In any event, most shoers have a new shoe keg price, and they charge a little less for resets. A reset means pulling the slightly worn shoes after 8 weeks or so, trimming the growth, and nailing the same shoes back on again. A guy'll charge much less for a trim, because you just use your knife, nippers, and rasp; there are no shoes to nail on. Shoes are not always hand turned, unless a person is working on a special class of horse. Many harness race shoes used to be hand made, but even they are manufactured now. Some show horses are shod with weighted shoes to give them heightened action. I formerly shod some Morgan show horses, and in the Park Horse class, I forged front shoes that had to weigh 16 ounces each with most of the weight in the toe of the shoes ('toe weights'). I used 3/8" x 1" x 10
Shop signs
My step daughter and my good smithing friend Winslow are "lysdexik." They both tell me that the condition DOES NOT affect their design sense. They say that while the printed page bothers them to a degree, they have an easy time seeing an overall design in their mind's eye. Of course, it takes practice to execute, whether you're dyslexic or non.
raised vein leaf
Schwarzkopf* shows a simple hand held chasing tool which has a slight curve on the business end. You run it along either side of what will eventually be the vein. It is often done cold, and you rock it along like an old fashioned can opener. You are setting down material, thus leaving the raised vein. * "Plain and Ornamental Forging" reprinted in 2000 by Astragal Press Turley Forge and Blacksmithing School : The Granddaddy of Blacksmithing Schools
Clinker Breaker
If you're worried about semantics, just call it a tuyere valve.
Magico-religous alchemy
Mircea Eliade wrote the book, "The Forge and the Crucible," and it was first published in French in 1956. We later got the English translation. Eliade was born in Romania and became a student of the renowned psychologist, Carl Jung. Eliade came to the U.S. eventually to teach Religious Studies at the University of Chicago. The book does not tell you how to make a dang thing. It is psychology in the broad sense, and includes the disciplines of religion and ethnology. For me, it was a somewhat difficult read, but worthy. Eliade discusses Chinese, Indian, and European alchemy. He includes some African tribal ideas on alchemy, and gets into initiation cermonies. Turley Forge and Blacksmithing School : The Granddaddy of Blacksmithing Schools
tips on forge welding
Gerald, Thanks for the safety sheet information. I didn't mention the force of hammer blows in my above post. It's been my experience to use relatively light hammer blows to start the weld, perhaps a half dozen or so. The key word here is "relative." A light blow on 3/4" square has more force than a light blow on 3/8" square. Speaking as a smith and not a metallurgist, I think the reason for the lighter blows is to obtain initial cohesion. Once the pieces cohere, you can hit harder. If you hit too hard right out of the fire, there is a chance for the scarf faces to "shear" (slide apart) rather than cohere. Some of us have experienced this in a lap weld where the piece on the other side of the anvil goes squirting across the room when hit. Sometimes it results from hitting the steel too hard. There are other reasons, of course; for example, scale and dirt may remain on the scarf, even though you have fluxed. There is another flux on the market that I like: Black Magic. A story. In 1982, I was domonstrating for the Quad State at the Studebaker Homestead in Tipp City, Ohio. I met the then-owner of the Anti-Borax Company, the guy who made Climax, Cherry Heat, and E-Z Weld. What was on their minds when they came up with those names? Do they have sexual connotations, or is it just me? Anyway, he said that all three brand names were just a ruse. They all came out of the same barrel. When he told me that, he laughed like hell. He said that some SWORE by Cherry Heat, saying that it was better that E-Z. Yet they were the same! The owner said that when he purchased the company that the special slag they used was in a huge vat. The seller gave him a little slip of paper with the formula, just in case he might run out of his supply. There did come the day a number of years ago when he ran out. He tried to duplicate the slag to no avail. The formula on the paper was bogus! He was frantic. He contacted chemists and smiths who might be able to help him. For a few months, there was no supply coming to the retailers. Eventually, they figured out a workable formula for the flux, and somewhere along the line, the company was named Superior. It is true that the newer version of E-Z is not quite the same as the old, but I personally find that it works just as well. Buena Suerte, Frank Turley Turley Forge and Blacksmithing School : The Granddaddy of Blacksmithing Schools
16th Century German Reenactment Utensils
The reprinted book by Dover, "Decorative Antique Ironwork," has some utensils from your period, most of them shown on Plates 380-390. The book is by Henry Ren
I've been forge welding for forty-five years. I don't know what a beehive is. Is that covering the hot coals with green coal? We used to call it a cave fire. Wetting the fines has been mentioned. That helps. The fire should be deep (high), clean, and compact. The fire can be open, but you need at least 4" of coke under the work and 2" of coke on top. You will not be able to see the piece, unless you make a peephole with your fire rake. Making a peephole is permissable. The work can contact the coke directly. When the workpiece(s) disappear from view by turning the same color as the surrounding coke, a dazzling, bright yellowish white, you have just entered the welding heat. Depending of the size of the pieces, give them 5 to 10 more seconds of blast and bring them out. To get rid of the surface soup which is a mixture of moltenflux, molten scale, and dirt, hit the pieces against the anvil or shake them in mid air. The soup will fall on the floor. Working by yourself? Lap the pieces on the anvil. The far piece is usually lighter, so the the heavier one can lever down on it thereby holding it while you reach for your hammer. Use the near edge of the anvil as a fulcrum/rest. Have your left thumb on top of the heavy piece, if you are right handed. Apply pressure and lever down. Francis Whitaker made a neat support for the far piece. He necked down and forged about a 2.5" length of round M.S. to fit snugly into the pritchel hole. With a forging heat and the round end in the pritchel hole, he bent the long end, about 1.5', down to about 90
Roger Lorance firepot, swage blocks
I've had the B1 swage block for quite a few years. The large circular depression is nice for jumping a bar when upsetting. I also have the C2 mandrel with the slot. Some people call it a tong slot, but it is often used when two rings are attached or when a ring and link are together.
wrought iron?
This is just my idea on 21st Century alchemy. You would do the entire process, mine the ore, build the bloomery, get a piece of iron from it, and make something worthy.
Borax flux warning
About 30 years ago, My bro-in-law, a geophysicist in Seattle, chemically analyzed some California mined borax and found miniscule traces of arsenic.
Can anyone ID this avil for me?
Sometimes, the Hay-Buddens have a 4" waist measurement, side to side.
aches and pains - looking for advice.
I'm the same age as Uri Hofi, but I started forging much earlier, beginning in 1963. I was presenter of a smithing workshop at Haystack School in 1981, and one of the students, Mary Greene, showed us a ChengManChing tai chi chuan short-form, and said that anyone interested could meet daily before breakfast for an introduction. When I returned home, I found a teacher who worked with the same form. I have been doing it ever since. It has to do with deep breathing and relaxation. It's good to do before breakfast. Much later, I learned a related method called Chi Kung (Qi Gong). Now I do both. I think it has helped keep me going. I will be demonstrating some of it and talking about it at a St. Louis workshop for BAM, November 21-22.
How Do I Elevate a fire
Peacock has got the idea. Don't try to save coal; cone it up around the fire. An old blacksmithing text says that the fire should be 1) DEEP; 2)clean; and 3)compact. Deep means that the coke bed should be about a 6" or 7" column in an ordinary firepot. If you're a skilled smith, you'll have your piece in the fire horizontally, unless it has an odd shape that won't allow it. You will not be able to see your workpiece, as it will be covered with an inch or so of hot coke. The coke on top acts as a refractory giving you a much quicker heat than if you just lay your work on top of a flat, lowdown, crappy fire. Beginners wonder how they can see the heat, if the work is hidden. You can occasionally draw it back to take a quick peek. Sometimes, you can make a peep hole in the top of the surrounding coke. With experience, you'll get a mental alarm set.
Look into the past
Those are ox shoes, two per cloven foot. The tenon-like, central projection on the one is a new one on me, perhaps a calk for traction. The nail crease was done with the striker. The nail holes were punched with the machine. It's really nice to see the old footage (pun intended).
- Aussie Brush Fires Leaf Memorial, make and send leaves.
