1,081 -
Everything posted by teenylittlemetalguy
Skill building weekends
teenylittlemetalguy replied to teenylittlemetalguy's topic in Alaska Blacksmith Association
Wow, that sounds impressive! It would be a good trick to have in the old toolbox. Phyre forge told me he cut the sides off of a larger postvise to make a 2" one and uses it daily. I could really see it being useful. -
For sure! Brazing in general is amazing stuff and usually much easier than people think. -
Exactly the same here. I know I will have a couple artists in the group that it will really help. It's like blacksmith hot glue... -
That is the one that made me rethink using mine for brazing small items. You could get a Meco Midget for about the same price and for little stuff that Meco is very nice as it weighs next to nothing.
In the forge. -
I am very happy to be working with Colter Fike to bring you two full weekend classes! Both weekends are focusing on skill building for beginners/intermediate by working through fun small projects. Below are just a few of the topics we will be covering: Shrink and stretch: Often misunderstood skills that you can use to your advantage. Project will be Spoon making (without the need for a swage block) Symmetry: Lay out with volume changes the easy way. Learn to create balanced designs with minimal math. Hammer swing tune up: Efficient hammering, no sweat! Brazing for the blacksmith: A valuable and underused metal fastening technique. 90 Degrees in Alaska: Fast, easy and accurate square corners! Tapers: The secret to graceful lines to your projects. Bringing it all together: Sunday we will combine new skills on a project. Weekend #1 April 10-11 Weekend #2 May 1-2 Classes at ; 2520 N. Meadow Lakes Loop. Wasilla Ak Payments and sign up can be done Monday through Friday 8:30AM to 3PM at Fike Industrial Construction Wasilla, Alaska 99623
I have a little B tank of acetylene that I have used as sparingly as possible over the years. I think it will probably go away now that I see the power of oxy/propane.
Yeah, victor makes one with different tip sizes you can change out and it fits my torch, they are pretty spendy though so I will likely outfit my other small torch for brazing.
Never had the chance. I am sure a brazing tip would be better. If I had a big brazing tip I would use it. For the price I'm pretty happy with the performance I have. Thank you! I feel a lot better about it all. Sorry it took me all day. The torch comes with a. N8 rosebud tip. Really surprised me with the speed. It took a cold 5/8" round bar up to a nice bending range in about 30 seconds. And the heated area was only about 1-1/4" wide. It's going to be super handy for me. I would be really careful about triple checking any accessories before buying them. It's all a giant cluster of misinformation out there. Thanks the info on the flashback arrestors. I will read up some more on that.
I would really appreciate that JHCC. I think the real answer for what head to use is going to depend on the size of your work. The heat area is pretty small with a cutting torch. I used the 1-3-GPN for 3/8 rivet and it was plenty fast enough for me, I wouldn't pay for a tiny rosebud to do something like that. If you are looking to isolate heat on a bend then a rosebud is going to do much better for you. There is one in the kit I have not even used yet. Let me try it in the morning and let you know how good it is on larger stock.
Happy to help! It was honestly a major PITA to figure out which series of tips go with that torch. I called Victor and even they got it wrong. Surprisingly my local welding shop did have a couple sizes of them in stock. 1-3-GPN came with it which I think is for 3/4". I bought 0-3-GPN for 1/2" and 2-3-GPN, which I think was good for 1" I am planning on getting a few more so I can cut up to 4". locally they are under $18 each, I see china models for $11 on line. I think am going to stick with the higher dollar ones. I am sure I will be yelled at by someone here for not getting the flashbacks yet. But I do plan on getting the ones that mount on the regulator once I figure out what part # I need.
I got a Victor Medalist 250 Propane kit last Xmas. Mainly for extending my cutting range beyond what my little plasma can do. I keep thinking up projects that need 1" plate or bigger. I had to purchase more cutting tips than comes in the kit to expand the range, but they are not crazy expensive. I am completely sold on it for rivets, worth the money just for that alone. I have been using the cutting head for brazing and while it works fine, it is heavy and clunky. The smallest tip turned way down is too much heat for brazing sheet in a nice controlled manner. Victor makes a propane "welding" style tip for the cutting body, but it is expensive plus there are more tips needed. If you just want to cut, rivet and braze 1/4" or larger stock then I would recommend the Medalist 250. I have a smaller Meco Midget torch I am getting small brazing tips for when I need to braze sheet as it will be more economical than the victor head and tips.
teenylittlemetalguy replied to Mark Ling's topic in Blacksmithing, General Discussion
that looks like fun! Do you have to paint them all as well? -
How do you hang your gas torch?
teenylittlemetalguy replied to Luke Rieman's topic in Welding Equipment
Jerry, regular 2 pc Victor cutting torch. I wanted to get "welding" tips for it as it is clunky to braze with the cutting head and way to hot for small stuff. They make one for oxy propane that replaces the cutting head and lets you use different size tips. It is expensive though. I did just learn that they make propane tips for my Meco Midget (which totally rocks btw) I am very excited to get the tips soon. It would let you control the gas with one hand as the valves are above the handle. I sure like Steve's hook, seems like a perfect solution to me. -
I just got an oxy propane as well, different style though and really like it. Best thing ever invented for rivets. I wonder if you will have room to make a hanging point in the gap between handle and head? -
Thank you Thomas, I will give that a try. Seldon would have approved, Scott. Good luck with the move. Yeah, Frosty he was such a good guy it really hurts. Give Deb a squeeze from us. Thank you all!
I wouldn't mind hearing the details on that if you don't mind. Thank you all!
Our fellow Smith and friend Seldon Jones passed away this weekend after a prolonged recovery from an auto crash. A Proud Alaskan Native and active tribal member. Seldon was tall and slender with a long black braid, he was a kind, enthusiastic person. Everyone was his "brother" or "sister" and he treated them like it. I am sure I now have many brothers and sisters out there that I have never met. He lived in many other places than Alaska, so you may know him from Tennessee, Kentucky, Missouri and more. Personally he was a big help for me starting out in blacksmithing. He would walk to my place and we would forge all day long, followed by a meal and sitting in the driveway talking about our plans for next time. I would personally appreciate it if you would give him Three rings on your anvil to send him on his way. Till we meet again Brother, Godspeed.
Oh he can bring it in my shop, will will keep it nice and warm...until it is wrapped for the freezer... -
I would love that! My shop is always open to you. -
Quick change bandsaw angle adjustment! Made a small Cam lock handle a while back and finally put it to work this morning. Wish I thought of this years ago. Put a scribe mark at 90 and 45 so I can quickly change. It was a real pain before, involving tools and measurements each time. -
I made a couple this morning before work and found a T that perfectly illustrates why I totally ignore the mold lines. You can see the mold mark is not in the middle. I don't know how they manage to make them like this, but I see it in many of the cheap box store brand fittings. To drill this T it was screwed onto a pipe which is mounted in the lathe and center drilled, so I know it is in the center of the pipe and why I think it is best to find the middle of your tube and then attach the T to drill it out.
Tapered is how I did it. Nice and smooth.
