forge build
Looking good so far! I went to smartflix.com and rented all of Steve Bleile's DVDs on welding and torch cutting. He covers alot of different processes and they use a camera with a welding filter on it to get some good shots of what a puddle should look like etc. I can sit and watch instructional videos like my wife watches the Kardashians (sp?) :-)
forge build
I like the cut and bend access channels you made. Saves on some welding.
Build Your Own Leg Vise
I think this is where they have their practice videos of the process. http://www.youtube.com/user/HAYBUDDEN#p/u/18/2SRjNpJLmCc
forge build
I meant to do the mock up too but don't have the time. I'm picking up the steel for mine using the Fab. Mild Steel Firepot design that has been posted. I can torch out all the sections from a 5 foot piece of 3/8" thick by 6" wide flat stock from the local welding supply. They're charging about $25 for the piece. I bought a Centaur Clinker breaker to use with it. Please post pics as you progress with it. It would be great to see. Rob.
"nordic" padlock
Nice job! Here are some similar designs. http://www.historicallocks.com/en/site/hl/Articles/The-history-of-padlocks/Viking-Era-800-1050/
New benchmarks in ridiculous
Do you think this guy would charge more if we told him it was used in the railroad industry "back in the day" http://cgi.ebay.com/Old-Hand-Made-Anvil-Found-Asis-No-Returns-/390193257740?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item5ad9549d0c
Need help finding age of Trention Anvil.
I looked in the Postman book, the A disappears by about 1913 and by the late 1930's the N started to look more like an X. If the 200 is the weight then the serial 210525 would put it between 1943 and 1945. Hope this helps, Rob.
Nail header
Take a look here. Header Plans I made one out of 1" X 3/4" I cut part way through and folded it back on itself then forge welded it. Then I drilled a small hole through it and size it with a file tang from the bottom. Rob.
ON/OFF valve for torch
That's nice! Do you light it with a striker or were you going to rig a pilot up or something? Nice mounting job too.
Nail header plans?
I made one here out of mild steel. I'm planning on using it for demos and some nails for a tool box. It's mild steel about 1/2" by 1" cut part way through and then bent over for a fagot weld. I drilled the hole and sized it with a round file tang based on a nail I started to tapper. I made about a half dozen and it seems to work well so far. http://www.iforgeiron.com/forum/f7/making-nails-refinements-14316/index2.html#post146480 http://www.iforgeiron.com/forum/attachments/f7/18975d1259078638-making-nails-refinements-nailheader.jpg Rob.
Frosty in the hospital (home Nov 09)
Good to have you back Frosty! "Last edited by Frosty; 11-23-2009 at 10:09 PM. Reason: spwlling. Can I blame it on trying to catch a falling tree with my head? " :-)
Making Nails, Refinements
I finally had a chance to try to make another one this weekend. I was going to weld some spring steel on top of mild. I found that my makeshift firepot can get hot enough to weld but is not a good welding fire. I need to get some fire brick to make the pot deeper. I get a massive amount of scale buildup. So instead I did a fagot weld. Then I drilled a pilot hole and shaped it with the tang of a round file. Once it cooled I made a handful of nails and it seems to work pretty well. I made another weld on the other end but haven't created the hole yet. I'm waiting to see what size I actually end up at. The nails in the pic start off as 5/16" round rod.
I guess everything comes full circle
There ya go! I'm going to takes the brakes off of that thing and stickem on the front of my softail. I'll never have to worry about a deer running into me again! Talk about stop on a dime :o
That's really interesting. I guess you need to be able to run off onto something at the end of the weld. At first I thought they were welding in a pipe hanger on the fly or something.
NASA - Friction Stir Weld Now they are "forge welding" the space shuttle. Pretty cool.
