40 ton hydraulic crimping press
I've crimped a lot of hoses on those presses. They are usually an air over hydraulic Enerpac style pump, single acting cylinder with a spring return. I guess you could re-power it with a more suitable HPU but I don't think I would. Not trying to rain on anyone's parade. Brian
Hydraulic press filter problem!!!
What does your gage read when the valve is not actuated (center postion)? This will show what it is taking to pump oil thru your basic circuit (back pressure). If it is above 75-100 psi you have a restriction somewhere and that is probably the source of your problems. Slamming the valve open and shut and inducing huge pressure spikes while forging with everything close coupled isnt helping either. Hoses do have an accumulator effect to damp out spikes. Nothing wrong with a low return filter, as long as the return truly is low pressure. Im not a huge fan of pump inlet filters because if they start to plug then your pump gets starved and cavitation could occur. Regards, Brian
"Inverted press" modification?
Those are typically used for pulling bushings into bores. Part on table, run ram up thru hole and bushing, split ring driver and keeper on top of bushing and pull it home. Much safer since stuff cant fly with a rod thru the hole. I've designed a few over the years. Brian
School/Class input needed
I am a member of the NWBA and attend their monthly events and conferences. I'm just looking for an excuse to travel to a different part of the country.
Last I heard Frank was recovering from health issues. I haven't looked to see if his school is still active.
Question for the group mind out there, I am largely a self-taught smith, couple weekend classes here and there. I would classify myself as an intermediate beginner. I am looking to take a weeklong intensive course at one of the many schools around the country. I will be flying in from the west coast, renting a car and driving to the school. I think some have on site dormitories, and all probably provide lodging recommendations. Who has taken what, where, and how have your experiences been? I think the immersive experience of such a class, combined with finally having a home shop to help lock in the techniques once I get back will really move my skills forward Thanks for any input Brian
Hydraulic forge press group build endeavor
One thing to keep in mind is that tonnage isn't everything when it comes to forging. A fast 25 ton press will outwork a slow 50 ton press all day long. If anyone is in the Hydraulic Press group on Facebook, you should look at the latest press Larry Langdon built for Jay Nickell. I helped hin with the hydraulics, its a single stage 7 gpm pump with a regenerative circuit to get the ram to the work quickly without using a 2 stage pump. The problem with the 2 stage pumps is they are way to slow (3gpm) when you need them to work. If you can keep the ram speed up around 1.5 inches/sec. you can get a lot more work out of it. Brian
Maintaining a coal forge in Portland
Your best bet would have been to attend the monthly Northwest Blacksmiths workshop in Longview, WA this last weekend. Jim vonMosch of Mountainbrook Forge would have likely been there (he has been at the last few anyway), and he usually has a few sacks in his truck and plenty more available. That being said, pretty much all the professional smiths, and most of the hobby smiths here in the Northwest use gas or induction in some combination. Coal is reserved for the oddball parts that don’t quite fit anywhere else, because it is so expensive out here. Check out the NWBA if you aren’t familiar with us; plan to attend our spring conference in Longview this May. If you need more information, I can probably help.
Trying to identify another anvil
Trying to identify as well as guesstimate a weight on this anvil. It's several states away from me, so I'm depending on the owners daughter for pictures and what I have isn't great. I did get some dimensions though. The rectangular face is 25.5 long and between 5.5-6" wide, 12" from the step to the tip of the horn, and 15.5" from base to top of plate. I'd like an idea on weight so I can come up with a plan on how we might load the darn thing. Its part of an estate and the tractors have already been sold off. I'm sure the collective mind here will have some ideas. Thanks Brian
4140 Forklift Tine Anvil & Introduction
15B30 is still a medium carbon steel, typically .35-.38 carbon. The boron enhances the hardenabilty. It will harden up if you have a way to effectively quench it. I have given lots of chunks away over the years to guys getting started such as yourself. They typically make a post anvil like you did (have been given some nice knives back in return from such anvils) or make striking anvils ala Brian Brazeal. They typically work fine as is for hot iron. Have fun, Brian
Has anyone tried cold working a leaf spring?
Almost the forklift forks we make (and I work for the largest manufacturer of forks in the world) are 4140 or 15B30. I have cut planty of forks in a metal cutting band saw with a good Lennox bi-metal blade. I'm sure you can get something close for a Sawzall, or even a hacksaw if you have extra time on your hands. They aren't anything super exotic Brian
Source for induction forge?
If you want to see one of these machines used in a production situation search for “nakedanvil” on YouTube. Grant Sarver was one of the early adopters of these machines and started bringing them in for sale. He used them extensively in his “Off Center” tong product line as well as many other uses. He was a frequent contributor to this and other online forums, with a wealth of knowledge to share.
Freon tank forge preparation
I’m not great at multiple word queries on this site, so at the risk of being referred to existing posts I’m looking for some specific forge build advice. I have obtained several empty Freon tanks for forge bodies and am not sure what I need to do as far as cleaning them. The valves are open, but before I fire up the plasma cutter, are there other cleaning precautions I need to take? I have seen references to Freon converting to phosgene gas when it burns, so the plasma cutter may not be the best choice. We are building Frosty’s T-burners, his construction document seems pretty straight forward, especially since I have a lathe. Insulation will be one inch wrap of Kaowool, with another inch of Kastolite inside of that, coated with some HYB-UV I got from Rex Price. I like the split shell Wayne Coe shows on his website, will probably incorporate that into one of them. Thanks in advance for the help Brian
Forklift Tine Anvil, Need Ideas!
Those are lumber forks, with the full taper blade and tall back height. The heels probably got too thin from them dragging them and they flunked the OSHA inspection. I'd make whatever out of them. Doubt they can "legally" be put back in service. Brian
Quick and Dirty Forging press's comming soon.
Larry, We have kicked several ideas around between us in the past but I think your biggest hurdle is going to be peoples available power. I don't know how to get the flow rates you need without 480 volt 3 phase power. It seems like this will significantly limit your market to the larger industrial folks. Maybe that is your target anyway? Brian
