Everything posted by Maillemaker
Something different
What are those faint white lines on the blade in the first photo?
- Well, that was different, triangles
Fuller Radius
So.... Bronze? Brass?
Measuring the Depth of an Etch
Has anyone bothered to measure just how much material is removed by the etching process? Obviously, the strength of acid, kind of acid, the time spent etching, and the desired severity of etch all have an effect, but if a smith wanted a very dramatic topographic etch, are we talking a thousandth of an inch? One ten-thousandth?
[Video] Forging a Small Bearded Axe
Another Stan Rogers fan, I see. Good on you.
Heating and Forge Welding?
Clean fire, clean steel. A flux of some kind, like borax or silica sand helps by forming a glassy layer over the steel that oxygen cannot penetrate. Your fire should be deep and free of clinker and slag.
- ASO from #110 rail
Riveted chainmail strength tested to destruction
In the colonies, there were laws against burning down your old buildings. Instead, you could have two "honest men" estimate the number of nails in a structure, and the government would compensate you for the agreed upon number, although the law was probably more about preventing wildfires.
- Riveted chainmail strength tested to destruction
Topographic Etch
Some of the most distinctive pattern welded steel I've seen has had a beautiful topographic etch. How is an etch like this produced? Is it all in material selection,or a specific acid? Thanks in advance!
- How big is your coal?
Forged some new tools
Fehu is also the rune for wealth and prosperity.
First try at a bearded axe
How thick was the blade when you cut the groove for the bit?
Best method to put an edge on a knife?
Hammer the bevels in as much as you can. As Peter Ross says, "ten minutes at the forge will save you an hour with a file". After that, care patience and practice.
Heat Treating a Blade 01 & 1520
Tripp: Located on the left side of your keyboard between the tab and shift keys is the caps lock key. Please turn your caps lock off when posting on IFI. You've been asked once already.
any chance for a hatchet, hawk, ax class in tue knife chat?
Homeshow, do you have access to a public library? Usually they have internet available.
Lil' drawknife
I've been away at school for a month and a half, and finally came home to heat some iron. Wasn't at it for more than a couple hours when this pretty thing popped out of the forge! Blade is 5160 left normalized, handles are elm with copper ferrules.
- Restoring a historic Smithy, looking for Blacksmiths
Help!: Wife doesn't want an "inside" Anvil
If she's really determined, she'll rent a hand-truck, or a guy with one. Perhaps there is another place in the house that she wouldn't mind as much.
Finding swage to make a metal screw for fastening wood together
http://video.pbs.org/video/1772044886 About ten minutes from the end is an excellent explanation/demonstration by Peter Ross as to how a thread swedge is used. http://www.pbs.org/woodwrightsshop/video/3200/3205.html At 20:11 Roy Underhill shows how a threadcutting plane is used to make wooden threads.
- Weight or volume??
Threaded Tangs
I was wondering about the strength and overall appeal to threaded tangs and screw-on pommels. I own a few sword-shaped objects that are all threaded tang, and while it does make maintenance easy, this has to be a cheap, modern method. I've had one of my SSO's pommel become loose, and wouldn't align with the blade, which annoys me to no end. Isn't a through tang stronger and more stable? Why would a blade or swordsmith want to "cop out" and use a threaded tang, aside from relative ease of construction? Wayne Goddard describes silver brazing a threaded tang in The $50 Knife Shop, but it doesn't seem like a safe long-term construction choice to me.
