Locking nuts
I have seen both nuts and bolts drilled and a wire attached as well as bolts drilled and Castle Nuts used.
Old drill bit - what new use for it?
Wow, I had to Google "Xeriscaping" Never had that problem before! It's either Snowing or green here.
Coal won't start ??? Suggestions
Jim, best thing I can think of is to put 2 pieces of coal in your pocket and by the time you land in Fla. they should be warm enough to light. "Flying out on Monday" Sheesh, Come back and watch us thaw out in the spring!
Christmas Ornaments
check the avatar, we made these from the MABA Nov Dec 2012 magazine
Forge Tools with a Different Twist
As always, Nice job Jim!
Box Hardware Inspiration
9e183957c835be741a9c09fde89090d5
Forging hooks with tongs
Thank you Frank T. for the tong idea. I have some offset ones but I like that idea!
Aspiring blacksmith in Mid-Michigan
Hi Enoch, Welcome! Jim Coke (above) has good advise here, MABA is very helpful and well worth joining,also the Woldumar Nature Center has a blacksmith group. If you need info on either of these, PM me. I'm not on here every day, but I try and keep up. Again welcome!
Fun forgings
I like the design on the Chef's Knife
cool pic of my basket twist
Would be a cool Avatar too!
Horseshoe hearts
Looks cool!
Art guild notification!
Well deserved! Those are fine submissions!
Victor rosebuds are backburning
Does anything here help? I have a Victor 100C that uses the same tips and I use the same pressures. Make sure you turn your acetylene up far enough to clear the smoke off the tip before adding the oxygen
Improving vinegar removal of mill scale
OK besides the PPE issue... Do this in a well ventilated area because when I did this, all the stuff in the immediate area got rusty quicker, if this is not an issue, just ignore. Just be warned, you are putting acid in the air and it will land on something. I use acids for color and I have learned over time to watch what is around me when I am doing this.
Sign Bracket
Very nice work on the scroll ends!
