Mason jar handles.
chickenman81
Made these little guys today. Only been smithing for about a couple months. Decide to try to make some stuff for Christmas presents for family and coworkers. The first one was quite a challenge trying to get the circumference right to fit the jar neck tight. And seeing that for an anvil all I have is a massive 50 lb chunk of I-beam I think they came out pretty well. Still need to clean them up some and apply a finish.
post-56575-0-99096000-1416704939_thumb.j
post-56575-0-75617600-1416705064_thumb.j
Welcome aboard Chickenman, glad to have you. If you'll put your general location in the header you might be surprised how many of the IFI gang live within visiting distance.
Pretty nice jar handles, a little polish on the idea and some refinements and I think those would be nicely marketable items.
Let's see now, you don't have to have the radius exactly the same as the jar so long as it's a LITTLE smaller so spring action holds the jar securely.
A little finial scroll on the ends of the prongs will make them easier to grasp and less poky. If you can get a decent grip on the ends of the prongs they'll be easier to get on and off.
A different but similar piece is a tea candle lamp. The iron work forms a handle and connects to the jar in a hair pin bend with the inside end making a spiral with a sharp point to hold a candle or hold a drip pan, etc. Versions of these lights can hang from hooks or a board, maybe a chair back, fence rail or wire, etc. just right for an evening picnic or toddy.
Thanks everyone. It's hard to tell in the pics but I did texture the handle with a ball pein hammer. I was going to try the scrolls on the ends but decided on these to leave them off. Next ones I do will have them. The spring action is actually what I had trouble with at first. One minute it's was to tight to fit on jar, the next it was not enough to hold securely. Def learned a lot. Thanks again for the comments.
Down here we call 'em "Shine Steins".
I made a jig from an appropriately sized piece of pipe for when I make them.
Sometimes I make them similar to yours, sometimes I fold a piece of 1/4" round then twist the handle.  There are several different styles of twists.
I do taper the ends and scroll them.  The length of the arms is slightly longer than half way around the jar.
