February 19, 200620 yr I generate an awful lot of them, but not really sure how and why they are formed. All I know is that they make a clink when they hit the floor. All comments welcome! Thanks
February 19, 200620 yr Well, Clinker is just the impurities of the coal, I think. Its usually silicon and whatnot, hence why its hard and glassy. Other than that, Im not sure.
February 19, 200620 yr They have to be specially recycled, because they are icky for the environment and decompose super-slowly.
February 19, 200620 yr I also develop a pretty decent amount of clinker, and I believe that it may be caused by too high of an air flow. I'm going to make some sort of a control gate for my blower so that I can vary the air I use.
February 19, 200620 yr Clinkers are normal. They are not bad for the environment. They are good for putting on your driveway and under your tires for traction in the snow. You can clear-spray them and call them art if your forging isn't going so well, which will allow you to still eat while you get your form back. Super high grade metallurgical coal doesn't have much impurity to it, so won't generate much clinker. Decent bituminous coal that cokes well and generates good heat, will leave a fairly tidy clinker in the firepot. That should be removed when you first build your fire or when it interferes with your fire, but is not that big a deal. With bad coal, you don't get much coke or much of a clinker... you get low heat, a rubble-looking fire, and a lot of fly ash. Rantalin: Clinker is not caused by too much air, it is just the by-product of burning the coal. If you are wasting coal by running the blower while not heating iron, your clinker will be bigger. You should definitely put a gate in any air system. See this discussion on blowers, particularly the comments made by Hollis about air control:http://www.iforgeiron.com/forum/viewtopic.php?t=873 Does anyone else here remember running track on this stuff???
February 19, 200620 yr thanks ed. All I meant was that the excessive amount of clinker I have is caused by so much air, which would in turn cause more coal to burn, and more clinker to form.
February 19, 200620 yr the clinker fairies bring them, and they drop them in the bottom of your forge!
February 21, 200620 yr then pull them out of your fire put them in a baggie and sell them as dragon fewmets for 5$ apiece
February 22, 200620 yr Author Hey buck!, whats a dragon fewmets? Actually I was thinking about selling some clinkers but I didnt think you could get more than 5 cents a piece. Just not worth the gas if you have to haul them to a blacksmith show. Maybe I should just sell my blacksmithing equipment? I only have three grand in equipment now. I was thinking of buying a trip hammer, but maybe I should wait until I sell at least one clinker before I convince myself that this is a good way to make money! If I could just sell one clinker than I could justify a 15,000 trip hammer. Makes good sense to me. Hey squeeze, If I had fairies coming to my forge like you, maybe I wouldnt have to work so Hard to sell them clinkers !
February 22, 200620 yr Fewmets or feumets is an archaic term for manure. You sometimes still see it used referring to dragon manure but it was used for animal manures in general---rabbit fewmets, dear fewmets, boar fewmets, etc usually in reference to tracking animals as "these fewmets taste fresh! Thomas
February 23, 200620 yr OK. I'm gonna tell you more than I know. Years ago, when I started blacksmithing for a hobby, I asked the same question. From two sources that I trust completely, this is what I came up with. Coal comes from the ground. There are bits of dirt, rock and other debris that are part of the lump of coal. When a smith is looking for coal, there are three things to be sought after. Low sulfer, low ash and high BTU's. Any coal will work but the more it fits these three things, the better it will work. The sulfer burns first and escapes in the form of thick green smoke. The BTU's are given off as the rest of the organics are oxidized (burnt) and leave the ash. Here is your clinker. The glass like composition is the result of melting the rock and stuff. Think about what is melted to make glass. Sand. Now I'm sure there is more to it, but they felt that the bottom line is, higher ash content - more clinker. Made perfect sense to me. Now let me ask a question. If all this is said, and I feel it's correct, then it stands to reason that charcoal would leave a different looking clinker since it is all wood ash. Does it? I've never used charcoal but I would like to hear from those that do. Thanks. Gobbler.
February 23, 200620 yr Only time I get clinker in a charcoal fire is when I've been forge welding. The rest of the time I just get wood ash that blows away when I crank the blower hard a couple of times. Scale and flux are two other components of clinker. Thomas
June 23, 200817 yr hehe old post... anyway i was wondering the same... i burn charcoal and i seem to awlys get a red hot black glassy mixture after.. i use sand arround my forepot in the cracks and sweep a little in but i doubt its melting! so is this black glassy mixture clinker from the charcoal?
June 23, 200817 yr I used to spray the clinkers with clear plastic, add a small fantasy figurine and get $20-30 each. Later on, I would put broken colored glass in the fire at the end of the workday and they looked pretty good. At the time I was using a very poor quality coal so the clinkers were rather large.
