carolinemsmith Posted January 4, 2009 Posted January 4, 2009 I am trying to find out if I can forge weld stainless steel? If I can how do I do this? Quote
larrynjr Posted January 4, 2009 Posted January 4, 2009 I have never tried it or seen any posts regarding that here but as it IS steel, I would think it is possible. BUT, if you are not proficient at forge welding other types of steel, you will probably have yourself a time, trying to forge SS as your first project. From what I understand about SS, it has a very narrow forging temperature window, I would guess that forge welding it would be an even more narrow time slot. Where are you located? If you go to the user CP at the top and list where you are located there might be someone nearby that can help directly. Quote
jake pogrebinsky Posted January 4, 2009 Posted January 4, 2009 Theoretically,yes.In practice-very difficult,and,depending on what it is exactly,would probably require an oxygen-excluding container.Here's some very good info on types of SS,Stainless Steel information - British Blades :: Custom Knife Making Quote
Frosty Posted January 4, 2009 Posted January 4, 2009 Yes it can be done but you need some really REALLY aggressive flux as the chrome oxide layer forms almost instantly on contact with air and you can't get a weldment through it. The fluxes necessary contain flourides which are darned toxic as are chrome oxides. Hey Jake how you doing? Taking a little chill time for yourself? Frosty Quote
jake pogrebinsky Posted January 4, 2009 Posted January 4, 2009 Hi,Frosty,hope that you've had great time these past holidays,and stay warm! Quote
Steve Sells Posted January 4, 2009 Posted January 4, 2009 Aggressive flux as well as an Oxygen-free environment is a must to forge weld SS, either argon injection to the gasser or many use "cans" to keep air from the metals. Not for beginners. Good luck Quote
Frosty Posted January 5, 2009 Posted January 5, 2009 Hi,Frosty,hope that you've had great time these past holidays,and stay warm! They were good for us, I hope they were good for you too. I like your thermometer. It's hard to find one around here that'll read below -40f let alone -100f and a wind chill chart too. That's just too cool. Frosty Quote
jake pogrebinsky Posted January 5, 2009 Posted January 5, 2009 Well,i won't worry about derailing this thread,as i think that Steve has pretty much stated it all,above. Frosty,as you can see,it's a promotional product distributed by our (utterly inane,regretfully)radio station.It's entirely possible that they can be made to tell which part of South East Asia they ordered these from!Maybe,one can get them with the Alaska Blacksmiths Assoc.logo,might make a neat item(for trade with the lower 48 savages,say).Unfortunately,not too many years ago,these same ones were made of tin,and were much nicer.But these are functional enough. Quote
Rob Browne Posted January 5, 2009 Posted January 5, 2009 Those temperatures are absolutely crazy!! Quote
jake pogrebinsky Posted January 5, 2009 Posted January 5, 2009 Nah,Rob,it isn't too bad.I did post it here for the shock factor,but in reality it's fairly livable.The way we,humans,cool/heat ourselves,or,more importantly almost,percieve the temp,has all to do with moisture. In an extra arid environment like here,with no wind,properly dressed,-50 is ignored by a competent outdoorsman needing to go someplace,or get something done. "Crazy" is a few hundred miles west of here,Verhoyansk range,where it was -68C(-154F)a couple of days ago.And still,those guys there get around,get stuff done.(Not without a breathing mask,though,much past -70,the lungs are an issue-you don't feel them getting frozen,till it's kinda late...). Quote
Dale Russell Posted January 5, 2009 Posted January 5, 2009 Burrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr No thanks Dale Russell Quote
devon blacksmith Posted January 5, 2009 Posted January 5, 2009 yes you can forge weld stainless I forge stainless and mild steel to make damask patern blades etc in a coal forge with a flux for welding cast iron the stainless is old butchers hacksaw blades (magnetic) Quote
brianklein Posted January 19, 2009 Posted January 19, 2009 what type of flux is need for Stainless???And can you forge weld two pieces of 416??? Quote
