December 29, 200817 yr As I was working today, it became apparent, I need a better system of storage for my drifts and files etc. All of my handled tools are hanging in racks , but the loose hand tools are all over the place, if you have solved this problem please help to alleviate mine!!!
December 29, 200817 yr go to the wreched antique scalper or mabe they are nice to you and get or look at old medicine crates or milk boxes they have a grid of boxes nd tipicaly hold tools well
December 29, 200817 yr Holes drilled in a 4x4, etc. works nicely for punches, drifts, chasing tools, etc. Files should be stored so they can't rub against each other or get banged into to prevent damage. A series of saw cuts in a board wide enough to hold files on edge works. In other cases I've seen 1/8" plywood used as dividers in a similar configuration. I'll wrap files in an old towel to protect them when going portable. Frosty
December 29, 200817 yr tractor supply sales discharge hose by the foot it makes danty sleeves to slide your files into when your going "portable"
December 29, 200817 yr I'm planning on making a rack for these types of tools by drilling holes in a board with another board below for them to rest on.
December 29, 200817 yr For file and chisel storage when mobile, I cut up an old sleeping mat and went for what might just be the cheapest looking french-fit drawers in the world. The empty hole in the upper right normally holds a scratch awl by the handle; obviously not too well. A little confession I should make is that most of my files bump around against each other in a box of their own....I'm really not a bad guy though.
December 29, 200817 yr working ends up, so you see at a glance what you want, and rod handles on the sides so you can pick the whole thing up and go. scrap 14 gauge sheet with short pipe stubs tacked on top.
December 31, 200817 yr my shop is smaller than Juniors ( lol ) but I keep the punches and chisels in a wood block ( visible to the right ) and drifts and other tools in seperate blocks. Files are in a wood box under the benchtop. Jewelers and other needs files are in a breifcase in the basement. I normally have a hot file or 2 by the vise in the shop. Wood blocks work the best for me in that they are ( blocks) portable. In the rear of the pic you see a wooden toolcase with auger bits ( brace is there too but not visible ). I also have wood boxes for handsaws and several for household tools ( plumbing, carpentry etc ). Wood is good. Edited December 31, 200817 yr by Ten Hammers
January 1, 200917 yr Author Thanks all, for the suggestions, as simple as it was, it is now finished, the ideas provoked me to come up with these solutions based on your input.
January 1, 200917 yr just picked up a good way to haul those things portable... hf had this neat fairly small canvas bag with a lot of pockets all around it ! for 10 bucks i couldnt pass it up !
January 1, 200917 yr Hey irnsrgn...Nice shelving. I realy like how you store the angle up against the receptical.
January 5, 200917 yr I have a square frame made of 2x4'swith holes drilled through to hold my files, and my dirfts all go in a bucket.
January 5, 200917 yr I scored an old metal test tube rack at an iron in the hat. I wired it to the side of my tool rack and it is perfect for storing things like punches and pencils. When I travel I store my punches in an empty Crystal Light container. They come in two sizes and have nice snap on lids.
January 7, 200917 yr I stor my chisels, drifts,punch in steel drawers onsheves . Every od is heving its drawer .when having a job take the drawer to the anvil when finish put it back in order all the tools are grind and resdy for the next operation.on this steel shelf i also stor all the small jigs and specil tools i forged to help production i have there drawers to acomulate tools from 5/16''-1 1/8'' hofi
January 7, 200917 yr Author Mr. Hofi, thats a lot more than I have to deal with at this point, but the storage rack is a good idea for growth, After watching you on video, I gained a huge appreciation for the simple tools, like chisels. The way you speak of them, is almost reverent. I find my appreciation of even the small things growing, simply by adopting your viewpoint. I very much look forward to taking a course with you.
January 7, 200917 yr Hello Mike First thank you for the compliment . Second my smithy is big and having many tools I think all togther more then 1000 so order must be maintained ,if a tool is not coming back to its place some times we look for it several month until by shear eccedent we find it . There fore all the tongs are pinted different and located on the wall in logic groups all the small tools are in cupbord sheves acc to the use the same with the hammers and different templates. this I started from day 1 if you delays this type of order it will be to late !!! this is my stat of mine .it saves lots of time and the smithy is allways under control. If I meet you one day in on of my classe I''ll just be HAPPY HOFI
January 7, 200917 yr Nice storage hofi. What video is divermike talking about? Can anyone view them or do you sell forging videos?
January 8, 200917 yr Author Element, At quad state this year, there was an individual selling quite a list of videos, mostly of conference demo's, the 3 disk set I bought was the 1st time Mr. Hofi taught at Tom Clarks shop I think. A student appears to have taken it, the quality of the video leaves a lot to be desired, but the teaching is worth the frustration, you might want to enquire at:UMBA Online thats the name on the dvd. good luck
January 10, 200917 yr I bought a couple of canvas carpenter's nail "aprons" ( not sure what you really call them) and I roll my files up in them. Portable, cheap ( about 2 bucks each) and keeps my good files from touching each other.
