larrynjr Posted December 22, 2008 Share Posted December 22, 2008 This was mentioned in the tenon thread recently and it is mentioned in the CBA Level III pdf as a tool to have. Does anyone have a picture of this? I'm not quite getting it from the description. Thanks! Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 22, 2008 Share Posted December 22, 2008 A search for Smoosh only shows up in one thread on IFI, making a burger press. We could really use some help finding the tenon thread, or CBA pdf in order to assist you. Quote Link to comment Share on other sites More sharing options...
piglet_74 Posted December 22, 2008 Share Posted December 22, 2008 I think this is the article from the Mark Aspery website. Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 22, 2008 Share Posted December 22, 2008 It shows up on pages 3, 4, and 5. Quote Link to comment Share on other sites More sharing options...
rthibeau Posted December 22, 2008 Share Posted December 22, 2008 I believe "Smoosh-a-matic" is Mark's term for a guillotine type tool. His is smaller than usual and fits into the hardy hole. Scroll down on the linked .pdf and you will see a photo of it.http://www.cbavista.com/sc2008/assets/DickFedders-StylizedFlower.pdf Quote Link to comment Share on other sites More sharing options...
Mark Aspery Posted December 22, 2008 Share Posted December 22, 2008 I use 1 1/4 inch heavy (120 thou) wall tubing to make a smoosh-a-matic. that gives 5 thou clearance for 1 inch bar inside. I'm not sure that I would make them as I used to. I think cut two sections of tubing and weld them onto a piece of angle iron. I like angle iron as it can easily be filed to fit a hardy and with a wedge fit 'kitty corner' it will fit in any larger hardy hole. Quote Link to comment Share on other sites More sharing options...
larrynjr Posted December 22, 2008 Author Share Posted December 22, 2008 http://www.iforgeiron.com/forum/f7/forging-tenon-7708/index2.html here is the thread from the forging tenon thread. MCraigl was the one posting and explaining. Quote Link to comment Share on other sites More sharing options...
larrynjr Posted December 22, 2008 Author Share Posted December 22, 2008 Thanks Mark, that fits the description that mcraigl had done on the forging tenon thread and what I was picturing in my head from that description. So it IS a type of guillotine tool, just with a much large working face. I may try to make one soon. Though the little blacksmith angel in my head says a guillotine tool may show up under the tree this year..... Larry Quote Link to comment Share on other sites More sharing options...
Quenchcrack Posted December 22, 2008 Share Posted December 22, 2008 Beautiful work, too, Mark. Quote Link to comment Share on other sites More sharing options...
Mark Aspery Posted December 22, 2008 Share Posted December 22, 2008 Thanks Mark, that fits the description that mcraigl had done on the forging tenon thread and what I was picturing in my head from that description. So it IS a type of guillotine tool, just with a much large working face. I may try to make one soon. Though the little blacksmith angel in my head says a guillotine tool may show up under the tree this year..... Larry It is a guillotine tool in terms that the dies are captured in the tubing. I don't use it for butchering in much as I use mild steel dies (although case hardening does help a great deal) I use the smoosh-a-matic to draw the isolated mass for the tenon out. I was always frustrated drawing out the peg when I was away from home. I usually form my tenons under the hammer - it is simply quicker for me that way. But away from home, I was always limited to using either the heel of my hammer (which I can do) or using a striker. My issue was one of the conference participant. Most do not have access to a striker and only a few would have the hammer skills to use a hand hammer. Enter the smoosh-a-matic. Light and easy to fit to any hardy (well most anyway). Quote Link to comment Share on other sites More sharing options...
Woodeye Posted December 23, 2008 Share Posted December 23, 2008 I started one of these based on the description in the Tenon string - good to see some photos here and better to see that what I am working on matches the concept - now if the Wisconsin temp can get more than 5 degrees above zero I'll finish it off. Thanks to all for the great information Quote Link to comment Share on other sites More sharing options...
NeatGuy Posted December 23, 2008 Share Posted December 23, 2008 Has anyone tried using an annular cutter to cut a tenon. I saw this on a website that I can not seem to find again. Using an annular cutter seems like the way to go for round tennons. brad Quote Link to comment Share on other sites More sharing options...
larrynjr Posted December 23, 2008 Author Share Posted December 23, 2008 not to be too dense but what IS an annular cutter? Quote Link to comment Share on other sites More sharing options...
NeatGuy Posted December 24, 2008 Share Posted December 24, 2008 An annular cutter is a type of corring drill used mostly but not exclusively in a magnetic drill press. To make a tennon the cutter would remove the outer part of the material and leave a core which would be the tennon. They offer many advantages cut much faster than a regular twist drill and make much rounder holes, and seem to be able to make tennons. I will try to make a jig to hold a mag drill and a piece of stock over the holiday and report back the results.http://mager.win.mofcom.gov.cn/www/4%5Cmager%5Cimg%5C2007422195934.jpg brad Quote Link to comment Share on other sites More sharing options...
