Ballpeen Hawk ?
I always drift out the eye larger to make handles last longer. I also use a hammer handle drift as it's easier/cheaper to buy hammer handles than hawk handles. I start by drifting with a bull pin as they are much tougher than my HH drift that was cast.
A good size is one you can fit handles to easily.
Morning Ron,
I've made a few and I start at the ball, forge it square and that gives you a good handle to forge the blade. I posted in the gallery (pawnee 1) some pics of ones I made, the first two, 32 oz head, were for reenactors the were doing the Lewis & Clark trip. The straight spike was a 16 oz head. Have fun with them.
Pawnee
Hi it's been quite a while since I posted on here,I have made many many of these,I drift the eyes out with a teardrop drift.Here,s one I did recently-16 oz.--Regards Butch
rsilver4, that is an extremely beautiful hawk. What did you do to affect the notches along the top of it, could you describe that for us???
Filing while hot???
So get the drift in the eye and draw it on the anvil?
Great Hawks
Ron, I use to drift across my vise. I open the jaws enough to accept the round part of the hammer and the drift. Then start drifting rotating side every other heat until the last few heats and then drift from just one side. I now drift on a stand I made just for this. Here is a couple pictures.
Thanks
I forged one today from a 24oz and use my homemade drift. My drift I left one side straight and tappered the others. It worked but makes the eye angle off from the blade- I think I finally straightened it will know after it slow cools.
That was enough of that I ordered a ductil iron drift.
You have a pic. of the drift that you use?
Should I drift the eye first ??
Thanks
Edited by Ron Hicks
I drift the eye first on ball peens and stock. Heres some pics of a few of my drifts
The one on the left I made to open the eye a little before drifting with the store bought drift. The eyes on the ball peens are a little smaller.
Heres another shot
Here is how I line everything up.
I think I have it now
What kind of steel could it be S7?
It was a Vaughan ballpeen.
I had anealed it last night and able to file on it but slow goin.
I got greedy and tried my angle grinder on the bottom of the spike. Im glad thats the only spot I ground on . Think I can get it with a new file.
How should I harden and temper this thing??
I made a few knives from springs and races.
Thanks
Ron
Heres another shot
Stu,I leave the drift in, put in the vise and use a piece of pipe to line the blade up.nanana my way is better--:DButch
But Butch, Listen to me. If the blade is parallel with the eye as this one is. Note that the spike is leaning the left. When you heat it back up and hit it with your pipe it is going to marr the side of the head!!! duh huh:D
Ron I have been told most ball peen hammers are L6 or 1045. Normalize a couple times before heat treating. I heat mine to non-magnetic,quench in trans fluid that is preheated to 140 degrees. Then draw back to a blue color. I only edge quench about 1/2 inch up.
