tompdw Posted December 7, 2008 Share Posted December 7, 2008 Has anyone inlaid glass in any project. If so any particular methods of doing it? I heard you put broken glass in the area to be inlaid, put it in the forge and melt it and then let it cool. Is that about right? Quote Link to comment Share on other sites More sharing options...
eyrian Posted December 7, 2008 Share Posted December 7, 2008 (edited) That sounds like (vitreous) enameling, specifically champlev Edited December 7, 2008 by eyrian Quote Link to comment Share on other sites More sharing options...
texasalterna Posted December 7, 2008 Share Posted December 7, 2008 my sister is a glass blower, and she has done a few things like this and she puts them in the kiln for a slow cool down to keep the glass from breaking. Quote Link to comment Share on other sites More sharing options...
NeatGuy Posted December 7, 2008 Share Posted December 7, 2008 The different COE (coeffiecent of expansion) between different glasses and steels will make your results difficult to predict. You may have better luck using glass rods for bead making and lamp work. Wrap the finished item in KAO wool if the glass object is not too large and you do not have a kiln this MAY allow the glass to cool at a slow enough rate. Forges tend to be on the rich side as steel does not like oxygen, glass likes oxygen. If there is not enough oxygen you glass will devitrify and become cloudy or have faded colours. Buy some kiln wash from a pottery supply. Coat your steel item with the kiln was an let it dry. This way you can remove the glass part and allow it to cool in a controlled envrioment or KAO wool ... if you can. The glass can be epoxied back into the recess later. This method will also help prevent the different COEs of glass and steel from cracking the glass. To start and crawl before you run ... If you use bead making rods heat your steel item in the opening of the forge. do not get it too hot you will know a good temperature when the molten glass sticks to the steel. Use a oxy fuel torch to heat the glass rods when the are a nice orange colour touch the rod to the coated end of the steel if it sticks you can carefully wind it on the steel. Once you have some success use the same process to fill a cavity you can add miliflori ( tiny sections of extruded patterned glass rods) to embelish your insets. Take a fusing/slumping or bead/marble making class ... Glass is great fun. brad Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted December 7, 2008 Share Posted December 7, 2008 it isnt that easy .. the problem is steel contracts at a different rate than glass ... when glassblowers do things like this they use copper because the contraction and expantion rate is closer . i dod a fair near the glassblowers and we tried a ring with glass blown in it .... it didnt work because too much of the glass touched the iron. good luck! Quote Link to comment Share on other sites More sharing options...
Ice Czar Posted December 8, 2008 Share Posted December 8, 2008 (edited) The different COE (coeffiecent of expansion) between different glasses and steels will make your results difficult to predict. and a third time ^ Ive done considerable research on enameling as its going to be a very important part of the pieces I've designed. 1. you probably will want a separate kiln for precise temperature control 2. you'll need to source and test various enamels[Ganoksin] Jewelry Making - Enameling - Metals Suitable for EnamelingLayout of Topics Grouped by Area (kiln design and automation)Resources for The Enamelist Society - Tools & SuppliesGlass on Metal Magazine - The Enamelist's Magazine if you want to see some impressive work google image these terms Basse-taille, Champlev Edited December 8, 2008 by Ice Czar Quote Link to comment Share on other sites More sharing options...
tompdw Posted December 8, 2008 Author Share Posted December 8, 2008 Looks like I have a lot to consider. I will do some experimenting and have fun. Thanks guys. Quote Link to comment Share on other sites More sharing options...
crij Posted December 9, 2008 Share Posted December 9, 2008 There was an article in Hammer Blow (Artist Blacksmith Association of America's magazine) about adding glass to ironwork, IIRC about 1 year ago. I will try and see if I can find it. Rich C. Quote Link to comment Share on other sites More sharing options...
781 Posted December 10, 2008 Share Posted December 10, 2008 UMBA Online has a DVD with Ivan Bailey inlaying glass with oxy/propane torch. He split and drifted a bar then placed layers of clear broken glass in the hole with one layer of colored sandwitched inside. He began heating with a torch from a long distance kind of snuck up on the glass. He said you had to heat slowly or the glass exploded and jumped out of the bar. As the glass heated up he used a plolished ball pien hammer to smooth and compact the glass. Dont remember if he post heated or not. I also watched a local smith melt a marble into a hole in a bar with a gas forge. Quote Link to comment Share on other sites More sharing options...
